Never thought of it...is this bad???
Old Jun 23, 2006 | 08:03 AM
lowbdgtmechanic's Avatar
Somebody ask me this past few days.
Is it bad if you dont run your car for a while??? Is this bad for the engine?? In his case, he only run the car 3 times every 5-6months. Does any of the tempereture[weather] share big effects on this?
Old Jun 23, 2006 | 08:31 AM
FartMuffler's Avatar
your should at least turn it on and let the engine run from 15 min once a week....
let the oil circulate, let the coolant circulate
Old Jun 23, 2006 | 08:46 AM
okay. any comments???
Old Jun 23, 2006 | 08:48 AM
lexat20's Avatar
+1
I would also move it some so no flat spots on your tires
Old Jun 23, 2006 | 08:55 AM
Aux.'s Avatar
Yes it is bad.
Old Jun 23, 2006 | 08:58 AM
Kc2Buk's Avatar
+1
+2
I would drive it at least 15 min a week to keep moving parts like the brakes, cluch moving free and run the AC too, if you got it.
Old Jun 23, 2006 | 09:00 AM
Dont Try To Run's Avatar
Definitely at least keep the car moving, or hell, give it to me, ill have to honors
TJ
Old Jun 23, 2006 | 09:01 AM
Talon's Avatar
Meh. I let my Eclipse sit the whole winter with the battery out. It sat for about 6 months and when I got in the first time, it fired right up. I let it idle for about 10 mins, then drove it cautiously, but there were no issues.
Old Jun 23, 2006 | 09:10 AM
thanks guys...i have a friend who owns the del sol with 260hp on it...he's a busy guy so he dont have time to drive it...he wants to race me but i guess it wont be smart for him to do that...
Thanks everyone.
Old Jun 23, 2006 | 09:14 AM
mdsevo06's Avatar
Your Seals tend to dry out and develop leaks, if not turned over at least once every couple of weeks. If you ever bought a used vehicle, with low milage, but quite a few years. That's one of the first maintenance you'll end up having to take care of, replacing seals.
Old Jun 23, 2006 | 09:21 AM
which seals??
Old Jun 23, 2006 | 09:38 AM
Dr. SS's Avatar
running it for 15 minutes at idle wont help, or even driving it.. he should take it out for a 20 - 30 minute highway drive to build full oil pressure and operating temp before shutting it off again...
just 15 minutes of low pace driving just makes more wear and tear like stop and go traffic....
Old Jun 23, 2006 | 09:58 AM
how much in week or month do you have to do this???
Old Jun 23, 2006 | 10:45 AM
Uncle Boo's Avatar
Bringing the car up to temperature will also remove any moisture in the exhaust system.
Old Jun 23, 2006 | 10:47 AM
coco's Avatar
battery can discharge if left conncted
