how many people run turbo timers and are they worth it??
Turbo Timers are not needed but if you want one go ahead. I have a slow drive through my apartment complex before I park, and I'm rarely on the turbo looking for a parking spot elsewhere, so I don't really see the point. However, in germany, I know at least one person went from sustained full throttle autobahn cruising to stopping at a rest-stop in and shutting off his engine in a 1g eclipse with non-synthetic oil. It never started again. I'm not sure what happened but it couldn't have been good.
Not needed, just use a little common sense; run the car for a minute at no boost before parking, and spend the $ elsewhere. I have a 1G TSI AWD I bought new; no turbo timer, 267,000 miles, never rebuilt. At best I run 50/50 synthetic/conventional, often no synthetic at all. After ~120k the seals on the turbos start to weep a little (traces of oil) and I change the turbo at that point. They still look new inside, no oil coking at all.
Originally Posted by SeanJhn9
the purpose for the turbo timer is to let the turbo cool down, not the engine or anyother component, but since stock turbo's are water cooled, they dont really need to be let cooled down, if running a bigger turbo, then yeah, a turbo timer is recomended...
Originally Posted by aznfballer79
to those without a TT, do any of you hear a popcorn pop noise coming from your engine bay after shutting down? try it and post up then decide on a 100 TT
every car makes that noise after it's turned off from driving around a lot. my moms minivan makes that noise. should i tell her to buy a TT??? NO.
a TT is really only needed for old oil cooled turbos, not oil/water cooled ones. although it doesn't hurt to have one for added safety. if you're on a budget don't bother and take the $100 elsewhere or save it for something that will add a little more power or save it incase you break something.
i've also heard of people running TT and coming outside after a hour or 2 and their car is still running, but i've also known people where they work fine. it's up to you if you want it or not.
from what i understand, a TT is not used to cool a turbo down...it is used to keep the oil pump flowing oil over the turbine bearings to keep them lubricated...otherwise, the turbine wheel may seize over time. After a hard run, your turbine is spinning at upwards of 100,000rpm. When you shut the car off, the turbine continues to spin down, but there is no oil movement over the bearings. I believe that is what a TT is designed for.
However, as mentioned earlier in the thread...with the synthetic oil that is used in our cars, there really is no need for a TT. Theoretically, the turbine would sieze up over time...but other parts of the turbo would probably fail first. I am running a TT in my Evo, but only b/c I already had it from my previous car
if you do track your car or beat on it repeatedly, i would recommend getting a TT or letting the car sit and run for a few seconds before shutting it off to give the turbine time to slow down.
03redtype-s
Dec 14, 2015 05:43 AM
03redtype-s
39
Dec 12, 2006 12:55 AM
