Is it common for Evos to idle rough with the AC on?
Old Jun 30, 2006 | 11:18 PM
touchmyjagee's Avatar
my car seems fine with the ac on. i really havn't noticed anything when i turn on the ac.
Old Jul 1, 2006 | 12:46 AM
ez76's Avatar
Originally Posted by mitsuorder
recently discovered that most of my idle blues were actually being caused by a trashed idle control motor.
Interesting - what were all your symptoms?
Old Jul 1, 2006 | 07:32 AM
Ph3n1x's Avatar
Got tuned and got the idle to set at 1k rpm when the ac is on.
Old Jul 1, 2006 | 07:52 AM
DrMerl's Avatar
IIRC this was more of a problem with the older Evos. My 03 had the same problem (car was stock), the rattle is from the throwout bearing, clutch in, rattle goes away. Never affected my car in a bad way except noise. My 06 MR has no such issue, but then again the bell housing and transmission are different (and redesigned for 5sp too).
Old Jul 1, 2006 | 02:43 PM
Frank Dux's Avatar
Originally Posted by BigBADGSX
my car used to idle a little rough when I turned the ac on. I got my car flashed and now it idles like a dream with or without the ac on.
I was wondering if this would make a difference. I think having an open air filter doesn't help either.
I was thinking something is wrong with my car. This is comforting.
Old Jul 1, 2006 | 02:55 PM
gmed's Avatar
My idle is ok, but lately ive noticed that when at the stop light, the car kind of feels like its not running smooth, I dont know if the injectors are dirty? I dont know. Could it be that i need a tune up? The car is a 2005 and only have 14K miles. I mean also have the problem with the AC, but even without it, the car doesnt run smotthly. Can someone give me a pointer?
Old Jul 1, 2006 | 02:59 PM
evolution_racer's Avatar
Might want to do a mild tune. You should throw new plugs in every 10k miles or so depending on how you drive. My car ('03) has the same rough idle with the A/C on and the noisy t/o bearing. They're inherent with most of the '03-'04 Evo's so don't worry about it. Luckily I live in the Pacific NW so I only need A/C a few times a year
Old Jul 2, 2006 | 03:24 AM
IXToes's Avatar
Happens to me too... the A/C on Evp's are straight up garbage so I have it turned off most of the time. My 86 tercel had better a/c.
Old Jul 2, 2006 | 06:39 AM
texrex2002's Avatar
Originally Posted by ch47god
my car idles like a busted diesel tractor with the A/C on. If i hold the clutch pedal in it goes away, it's just how the setup is
^ totally.
it's like the throwout bearing and the ac clutch /belts / whatever rattle like everything is going to fall out and onto the ground.
not sure how mitsu released a car like this...
oh well. that's why I need a stereo upgrade
Old Jul 2, 2006 | 06:45 AM
sleet's Avatar
My 280s and AC aren't friendly, it's rough as hell
Old Jul 2, 2006 | 07:10 AM
EvoIXMR's Avatar
My evo is all stock performance wise and my AC idle definitely seemed to improve after my grounding kit install.
Old Jul 2, 2006 | 07:56 AM
lukytry's Avatar
My car too , when stock had a bit of a rough idle. its 100 plus deg here in az though, so im not sure if heat has any part in the lower than normal idle.
Ever since my tune problem has went away!
Old Jul 2, 2006 | 08:09 AM
bluepeartype-s's Avatar
Registered User
Honestly I agree the idle sucks with AC....and I really don't even use mine that much in AZ....like previously mentioned...thats what windows are for....putt'em down!! it's like a 105 here every day!!
Old Jul 2, 2006 | 05:42 PM
AHHH!!!!! Reading that makes me want to kill myself
Old Jul 2, 2006 | 08:51 PM
porque's Avatar
I put a deposit down on a different Evo today. I'm going to pick it up in a couple weeks, these are going to be the longest weeks of my life.
