Restore Engine Restorer
Old Jul 4, 2006 | 06:15 AM
kike_4g63IV's Avatar
Originally Posted by timzcat
stop smoking completely for about 3 days. Worked well enough to sell it.
American way,huh? Thats fu!@$# up
Old Jul 4, 2006 | 06:18 AM
bigfishs's Avatar
If your car smokes and this cures it, it will only cure it for a while. Its most likely time for a rebuild. I know a guy at work who used it for a month or two becuase his car smoked like crazy. It worked, then the smoking got worse and it was new engine time.
Old Jul 4, 2006 | 06:47 AM
MalibuJack's Avatar
Not so sure this stuff is a great idea to use, I've used it in older cars that did have alot of leakdown, but who knows.. It doesn't last very long..
The stuff basically has a very fine resin type powder that fills scratches in the cylinder walls, I would be concerned that using it for an extended period of time could increase wear elsewhere.. Or at least gum up a oil filter..
If it works, cool.. but Its not a perminent fix, it'll certainly buy you a bit of mileage before a rebuild.. Unfortunatly with a turbo car, with high cylinder pressures, I'm pretty sure your compression would return to its previous state pretty quickly.
Old Jul 4, 2006 | 07:27 AM
Xfer's Avatar
^^ I agree. Used it before in my delivery truck to put off rebuild...but only made things worse when I actually had to rebuild. Alot of gunk built up.
barneyboo
Jun 29, 2017 02:09 PM
repto
Mar 6, 2016 05:02 AM
Evo_SpeedKing
15
Feb 11, 2008 09:50 AM
1_900hustler
Automotosports - Illinois
38
Feb 1, 2007 07:35 AM
Boost20psi
Apr 2, 2006 04:17 PM
