Water/Alky kit
Old Jul 8, 2006 | 03:17 PM
gl4662's Avatar
Water/Alky kit
I am deciding between Aquamist DDS3 or the SMC kit. I would like one with a failsafe unit, and I hear that the SMC kit doesn't have this? Any suggestions/recommendations would be appreciated!
Thanks!
Old Jul 8, 2006 | 03:27 PM
mooreboost's Avatar
Snow Performance.
Old Jul 8, 2006 | 03:32 PM
gl4662's Avatar
Better than the two? Could you point me into the direction for more info? Thanks man!
Old Jul 8, 2006 | 03:56 PM
Dr. SS's Avatar
Thanks!
which vendors are u looking at? wanting to price the different units..
Old Jul 8, 2006 | 08:17 PM
SlowCar's Avatar
Thanks!
get both. the smc is for injection, DDS3 is the fail-safe, to prevent your car from blowing up your car when something in the injection system fails.
Old Jul 8, 2006 | 08:22 PM
Saikou_kun's Avatar
Listen to Slowcar, FTW!!!
Old Jul 8, 2006 | 08:33 PM
SlowCar's Avatar
Yo Manny!
Old Jul 8, 2006 | 08:55 PM
mooreboost's Avatar
http://www.gruppe-s.com/Evo/evoeng.htm
Scroll down to the Snow Performance alky kit with Failsafe option.
Old Jul 8, 2006 | 11:50 PM
gl4662's Avatar
Are the failsafes for each different system pretty much all the same?
Old Jul 9, 2006 | 07:21 AM
SlowCar's Avatar
yes and no. Yes.....the 2 that are commonly used aquamist/snow are flow type sensors. No...the snows unit is a fixed flow rate detection whereas the aquamist one, you can set upper/lower limits of flow
https://www.evolutionm.net/forums/at...chmentid=80175
Old Jul 9, 2006 | 08:46 AM
gl4662's Avatar
Which vendors sell the aquamist unit?
Old Jul 9, 2006 | 09:01 AM
eve-slow's Avatar
Nice set-up you got there
EvoTio's Avatar
Aquamist is the pioneers of fail safe awareness. I've had my Aquamist system on my Talon for several years and now I am using the the same system on my Evo. That shows you that they are indeed durable. Try Georges Imports:http://www.kcsaab.com/. Ask for Brad, he's very knowledgable and can advise you about anything you need to Know. Here's my Aquamist intall/set up if you want to check it out: https://www.evolutionm.net/forums/sh...d.php?t=173840
Old Jul 9, 2006 | 09:17 PM
gl4662's Avatar
I couldn't find aquamist on the website. Also, does the snowperformance kit install in the trunk like the SMC?
Old Jul 9, 2006 | 09:22 PM
EvoTio's Avatar
Here ya go for the Aquamist website: http://www.aquamist.co.uk/. I would believe that any kit can be made to install in the trunk.
