Idling problem !
Old Jul 11, 2006 | 04:15 PM
Graphite_MR's Avatar
Idling problem !
I just put a hks racing intake and a turbosmart dual port blow off ...... The sound is amazing .. I mean the turbo spooling and the blow off sound... But i have the idling problem.. When at idle the car would go to 500 rpm even lower...It doesnt die bit still it bothers me.... I was told that tightening the blow off adjustment bolt would fix but it doesnt... Does anyone know how to fix it and why it does it...???
Old Jul 11, 2006 | 04:21 PM
xmaciek82x's Avatar
Search BOV, u will find alot of answers.
Old Jul 11, 2006 | 04:36 PM
BLiu's Avatar
It's not just the BOV. The HKS Intake is giving you problems as well. You will need a tune to fix it.
For example, I have the HKS intake, got an ECU flash, after that no problems. Now, I have cams installed and I need a retune. The idle problem described above is happening to me now.
Brent
Old Jul 11, 2006 | 05:05 PM
Sidewayz.net's Avatar
Intake should not cause the idle problem. It is your bov. Did you try the stock bov with the hks intake. It would of had more of a sound to it. Best bet would be the forge recirc bov.
Old Jul 11, 2006 | 06:15 PM
Brent
Thanks for the advices... I have not tried them separetely but i am getting a turbo back and ecu flash so soon i will know weather a tune will help... Really hope thats the problem cos i like this set up and the blow off sounds very nice... Thank you all !
Old Jul 12, 2006 | 09:28 AM
BLiu's Avatar
Not to be rude or anything but do you even OWN an evo????
Have you searched through the form to find out how many people have run into issues with an intake WITHOUT an ECU tune????
Before you do that, please don't discredit good advice. Thanks
Old Jul 12, 2006 | 09:31 AM
byron3636's Avatar
sounds like there's a leak in the intake setup somewhere and more air is getting into the system than the MAF is reading.
Old Jul 12, 2006 | 09:32 AM
gsrboi80's Avatar
Sidewayz is right its not the intake its the bov. If the original poster wants reassurance of this just put the stocker back on. Hey what do you know idle is back to normal.
Old Jul 12, 2006 | 12:26 PM
I will try the stock blow off too but yestarday i was playing with it and i found out that the spring had to be tightened.... i made it hadred and it gor better so i think it was the blow off ... it seems normal now..
