bad wheel bearing causes shaking?
Old Jul 23, 2006 | 03:50 PM
deegaw11's Avatar
lately whenever im driving and it doesnt matter how fast or slow im going there is a noise coming from one of the wheels. the noise sounds like something is thumping. it sounds sort of like when u driving with a flat tire. all my tire pressure is good. whenever i hit a bump the steerin wheel shakes and my steering wheel also shakes tremendously whenever i hit the brakes, even if my rotors were bad this wouldnt cause my steering wheel to shake whenever i hit a bump. it also shakes when i make turns at a certain speed. i can feel it on the steering wheel and the car when its makin that thumpin noise. it scares me sometimes because it feels like the wheel is loose or wants to come off while im driving but all the bolts are tight, i dont know what the problem is so any suggestions?
Old Jul 23, 2006 | 04:26 PM
EiEVO's Avatar
obviously the culprit is something to do with the suspension. If it were a wheel bearing you would hear a loud roaring noise all the time. Especially when going around 50 mph. The only way your steering wheel would jerk like that if it were the bearing is if it was ready to come apart as of now.... I have seem some bad wheel bearings before but nothing really to make the steering wheel to jerk like your explaining. It seems to be in the front of the vehicle. So jack it up get the front wheels off the ground and when your car is in neutral and the wheels are on tight try to move the wheels from top to bottom with one hand on the top of the tire and one on the bottom and see if you can feel "ANY" play. And if you do have any then it is either a ball joint or a wheel bearing. If you have noticable play from left to right with your hands on the tires in the opposite locations then you have a bad tie-rod. It could be a bad control arm bushing or just about anything else. But hopefully this helps you out.
Old Jul 24, 2006 | 04:18 PM
deegaw11's Avatar
nope no play at all..when i hit a bump u can hear this slight rattle like something is loose. it's getting really bad and it feels like the wheel is loose but all the bolts are tight and there is no play whatsoever
Old Jul 25, 2006 | 03:40 PM
FLAEVO's Avatar
It sounds like your strut is shot. It is just working with the spring,no oil in it.
Old Jul 25, 2006 | 03:44 PM
RazorLab's Avatar
The steering wheel would shake all the time from a bad wheel bearing. I am replacing my bearings right now and that was one of my symptoms.
Old Jul 25, 2006 | 03:59 PM
inco9nito99's Avatar
Bad wheel bearing would make a noise when you turn and go away when you're going straight.
Old Jul 25, 2006 | 04:19 PM
EiEVO's Avatar
Not true... Depending on how bad it is. Normally you get a roaring noise when going straight and a lound grinding/rubbing noise when turning.
Old Jul 26, 2006 | 07:10 PM
deegaw11's Avatar
the shaking was due to my rotors and you're right, the driver side shock has a leak and im lowered on stock shocks. a strut leak would cause a rattle when i go over bumps?? when i had my integra all the shocks was gone but it never rattled at all.
idiaroi
Jun 8, 2016 07:27 PM
akride907
Mar 17, 2016 02:13 PM
princess33
Sep 14, 2014 08:08 AM
LiveAndLet
Lancer Troubleshooting
Aug 26, 2007 12:06 AM
PersianEVO
Jul 11, 2005 05:08 PM
