Cigarette Lighter broken..
Old Jul 26, 2006 | 04:06 PM
Evo#1's Avatar
Originally Posted by Evil8MR
Get the direct wire kit, and run it behind the A-Pillar. Trim the metal lead, and install it in the fuse panel. No more dangling cords!
I plain on doing this with my radar detector because I have an in-dash DVD player and the wires going across the screen sucks
Old Jul 26, 2006 | 04:09 PM
SASD209's Avatar
Admin Alumni
Well, if you hold it in for like 6-8 seconds and it doesn't get hot, you have other kinds of problems. Also, I installed LED dashlights by coming off the back of the lighter and running the wires across and under the floorboards, up the pillar, across the top, and to the back of the rear-view mirror. Just takes a bit of time and effort to tuck them away good. Everything snaps or goes back into place.
Old Jul 26, 2006 | 05:59 PM
heSOshAdy's Avatar
Thats exactly the case with me. Doesn't matter how long I hold the lighter in it won't heat up. However, the light that surround the lighter still lights up. Does that mean I have to order a new unit?
Old Jul 27, 2006 | 09:32 AM
RALLIART2U's Avatar
Hi guys Im working on this now and find that the cigarette lighter has a fuse link on its base. You have to remove the console and find the lighter's nut that locks the positive wire .If you look around it you will find and L shape black wire crimped to 4 contacts .It should be blown (if you already checked your fuse on the drivers side behind the coin compartment) .Now you have to remove the nut to remove that part and go for replacement on the dealer or like me, solder another piece of wire or a small fuse to it . It was hard to find this with my ohm/volt meter but here it is. Good luck !
boostincincy
Apr 1, 2015 07:36 AM
Levar
MitsubishiParts.net - WA
Mar 27, 2012 08:29 AM
Jacoby
18
Dec 20, 2011 08:55 PM
Lightsped
Mar 2, 2011 06:55 AM
azn6oy
Lancer Troubleshooting
Dec 10, 2005 09:28 PM
