Wanna make your EVO handle even better ?? Battery relocation!
Old Apr 30, 2003 | 04:52 PM
Alfriedesq's Avatar
Originally posted by chronohunter
Alfriedesq, can you still fill your windshield washer fluid?
If you can (when you post the pics) list all the pieces an prices
Yes - there is enough room to fill the washer tank
Pics will come hopefully later tonight on my web page
Old Apr 30, 2003 | 05:04 PM
langjiy's Avatar
What about the cables?? How much weight does it add to the car after installing them??
Old Apr 30, 2003 | 05:26 PM
WestSideBilly's Avatar
El Jefe
Re: Wanna make your EVO handle even better ?? Battery relocation!
Originally posted by Alfriedesq
The weight transfer was substantial
Do you have any proof of this? Did you corner weigh the car before and after?
However - my testing tonight showed that the handling gains were DRAMATIC - it handels even more neutral than before
Do you have any proof of this? Preferably handling diagrams based on a constant speed steer sweep.
a lot more grip
How did moving the battery box alter the physics of the tire/road interaction?
I donty kknow why they dont ship the cars with the batteries in the trunk in the first place
Because it's ridiculously expensive.
BTW - yes it was slightly costly bny the time you add up the cost of all those monster cable battery connectors - 1/0 monster wire and fancy fuze blocks - but - it makes a huge gain in hadnling area - - - the stock was just puts too much wieght up high and too far forward
Did you consider that, in addition to cost, you've also added quite a bit of weight? You've added 15' of heavy cable, connectors, fuse blocks, and an aluminum battery box. I'd estimate that to be at least 15 lbs. While the change should improve the performance, I question whether the cost and added weight really justify your claims of improved handling.
Old Apr 30, 2003 | 06:37 PM
cwest's Avatar
Also, how/where did you route the battery cables?
Old Apr 30, 2003 | 08:10 PM
Alfriedesq's Avatar
Re: Re: Wanna make your EVO handle even better ?? Battery relocation!
no proof - - just my obeservations - it really made a huge improvement - even more help than when i did it to my WRX - the evo seems to really like weight off the front and also high up like the stock battery is
It would prob be more cost effective to put in a smaller battery - - but I like the idea of having that big stock battery come winter time
yeah the whole thing weighs a lot and costs a lot but - - - now i can re-route my intercooler pipe to make it straigher and shorter - and like i said - it handels better
Old Apr 30, 2003 | 08:23 PM
SOF's Avatar
SOF
Isn't the trunk farther away from the center of gravity than the original battery location? You just messed up your car's polar moment of inertia! You sure it doesn't handle worse now?
Old Apr 30, 2003 | 08:28 PM
cwest's Avatar
Some of you guys are really geeking out over the battery. It is obviously better. Better weight balance, better handling. Stop over-analyzing it. Polar center of gravity? my god.
Old Apr 30, 2003 | 08:31 PM
OnlineAlias's Avatar
It isn't expensive to move a battery to the trunk. Just some longer cables....you don't have to spend a fortune on audio specialty ones. I'd say changing the front rear balance from 60/40 to 58/42 (if you care to do the math) in one small move is huge. I can't believe didn't do it either.
Too bad the autox stock rules won't let you do it....now I REALLY wish had...
Old Apr 30, 2003 | 09:18 PM
Alfriedesq's Avatar
It came to a lot of cash becuase I did it in a very nice way - i used the summit racing polished alum battery box (which is really very great) a monster junction box up front to accept the 1/0 gauge wire and the stock 12 V leads - - two monster batt terminals and a junction in the back for my amps Oh and not to mention the fuse block - all told it was a $450.00 set of parts including the cable
Old Apr 30, 2003 | 09:53 PM
bobaab's Avatar
well with a 60/40 weight distribution, being farther from the center of gravity would make it balanced.
so if the car weighs 3000 pounds, the front end would be approx. 1800 lbs and the back would be 1200 lbs. now take away approx 45 lbs from the front and add it to the back..that would make the front 1755 and the back 1245 lbs.this would make a 58.5/41.5 weight distribution..i GUESS that would help, but like SOF brought up, the spot in the trunk may be farther away from the center of gravity than under the hood so the weight distribution may be more even..i just felt like doing simple math
Old Apr 30, 2003 | 11:29 PM
ancer06's Avatar
exactly
so it wasn't $15 worth of cable.....i'll even give the benifit of the doubt abuot the 90lbs. not worth it unless you're into your car's performace, which you are....so that's cool.
Old Apr 30, 2003 | 11:35 PM
Alfriedesq's Avatar
The rear is perfectly balanced - - it seems like the whole car is much more resistant to sliding - like the threshold for sliding at all is raised higher - - once it acftualy starts to rotate around in the back I can not feel any difference at all - it seems the same - but then again I have not had that much drifting action as the car has few miles
IF you wanted to - you could mount the battery low down in the spare tire well (but I am using that for a sub box location
PS - I would have prob kept the battery in the front also - or merely added a smaller battery IF I had not been adding a mcIntosh amp in the trunk and needing to run a at least 4 gauge wire from the front to the back for the amp - - if you are installing a power amp then it makes it much less difficult to run a bigger wire and just move the battery
When looking at the improved apperance of the engine compartment - the better handling - and the ability to run a shorter and straighter intercooler pipe - I'm glad I did it
Old May 1, 2003 | 12:48 AM
RA29's Avatar
What's a Batcap? Please elaborate?
Thanks
Old May 1, 2003 | 10:51 AM
ru4real's Avatar
Alfriedesq, will you post pictures today?
How much weight do you estimate you added for the battery relocation cable and other parts?
People can consider doing the battery relocation with a lighter battery at the same time, so that the net weight change may be zero or even negative, while still removing weight from the front wheels and gaining engine compartment space.
For those that are experienced in the rules of autocross and track days, how is stock battery relocation and/or substitution addressed?
