Wanna make your EVO handle even better ?? Battery relocation!
Re: Re: Re: Wanna make your EVO handle even better ?? Battery relocation!
Originally posted by OnlineAlias
It isn't expensive to move a battery to the trunk. Just some longer cables....you don't have to spend a fortune on audio specialty ones. I'd say changing the front rear balance from 60/40 to 58/42 (if you care to do the math) in one small move is huge. I can't believe
didn't do it either.
Alfriedesq's subjective evaluations are highly biased based on the fact that he spent all that money to move it, so it must be a "major" improvement. Several of his statements lead me to believe he either has no grasp of vehicle dynamics or no grasp of the english language. I'm leaning towards both. Butt evaluations of minor changes in corner loading are about as accurate as butt dynos, and adding 20 lbs of vertical load isn't going to drastically alter a tires ability to exert a lateral force.
When looking at the improved apperance of the engine compartment - the better handling - and the ability to run a shorter and straighter intercooler pipe - I'm glad I did it
anyways, thanks for the info, wondering if you were planning on putting new IC pipe on now that you can.
Originally posted by ru4real
Alfriedesq, will you post pictures today?
How much weight do you estimate you added for the battery relocation cable and other parts?
People can consider doing the battery relocation with a lighter battery at the same time, so that the net weight change may be zero or even negative, while still removing weight from the front wheels and gaining engine compartment space.
For those that are experienced in the rules of autocross and track days, how is stock battery relocation and/or substitution addressed?
Any weight gains were more than offset by the removal of the spare tire which was really quiet heavy
Re: Re: Re: Re: Wanna make your EVO handle even better ?? Battery relocation!
Originally posted by WestSideBilly
A penny of unnecessary cost will stop a car maker from making this change. The cost is unnecessary. The benefit is more like 60/40 to 59/41, not factoring in the added weight of the cable or battery box. Consider that the difference between a full tank and empty tank is going to shift the weight from 60/40 to 62/38, a rear-seat passenger will make that 60/40 more like 58/42. The benefit of moving a 35 lb battery from the engine bay to the trunk is greatly outweighed by the $3-5 of cost it would add in cables in the view of a manufacturer. It would be great if they could be uncompromising with regards to performance, but they can't. If you want no compromises, you'll have to get a supercar.
I dont care what car manufacturers do or don't do - - I do what ever I want to my car to make it work better and go faster
If you don't like how I write - then dont read my posts
Uh, hollow cams is for faster revving primarily...
To all those talking about how it will only shift weight dist. from 60/40 to 59/41 are forgetting to take into acount how far from the CG the battery's mass is (i.e. it has a very long "lever arm"). In terms of polar moment inertia, this makes a big difference. Al's comments have been mostly about handling in regard to the car's "rotatability", which is much more affected by polar moment of inertia than by simple weight distribution.
Not to mention the fact that Al was just telling us something he did that he felt helped the car's handling ... and somehow this turned into Al having to defend against attacks from some .... well anyways thanks for the info Al.
dont forget to add that cutoff switch if you plan to take the car to the drag strip. any car with a relocated battery requires a battery cut off switch to be located in a very visible location in the rear of the car.
after alot of discussion on this debate ive learned that 50/50 weight balance isnt as important as a lower center of gravity. going by that the best spot to relocate the battery would be under the passenger seat, possibly a hawker or any other small battery, or possibly two in parrallel for those of you with the bling bling "ice".
just my .02
just my .02
of course
if you make statments about how much better your car performs becuase you did something nobody has done (to the evo's), then heck ya you better be able to back it up. what did you expect, everyone to say "you are sooo smart, i want to spent about $400 to do that too." it doesn't make sense for the supposed 90lb. swing. unless you're filthy rich, then you're just dumb. do weight reduction if you have money to burn and you want to drive as hard as you supposedly drive. IMO.
Re: of course
I remember on the i-club when non wrx owner drivers of the castrated so called subaru 2.5 RS they sold to the american market before they released the wrx used to come on and post stupid insults about what i was doing to my WRX like they were somehow feeling a personal attack becuase I choose to do some modifications to my car
here we got some guy who dont even own an evo making stupid rude remarks against me because i am trying to share techinical info about what i am doing to my evo -
instead of wasting your time making insulting posts - get a 2nd job so you can afford a real car
ha. thats funny. i remember on the wrx forums you used to attract alot of this crap. there always seemed to be an arguement going on with you in the center, or at least on the sidelines. maybe as a lawyer its in your blood to argue??
Originally posted by broken
al, did you remember to add that all important cut off switch yet??
As i plan to be deep into the 11's within a few more weeks I prob wont be able to run the evo at any drag tracks in any event as I will NOT put a cage in there
I am sure I won't have any problems at tech inspection - but if I do - i just wont run
I certainly am NOT going to mount any battery switches on this car
i went to the strip last night and they actually checked to see if it had a clutch switch. some tracks care some dont. my gsx had a battery switch that technically didnt work as i didnt attach it to the alternator, they checked to make sure it worked and when it didnt they signed off and let me run anyhow. alot of trcks just dont car all that much.
