part question
Old Aug 12, 2006 | 11:31 AM
anikisama's Avatar
part question
I have a 2004 Evo VIII. My clutch has almost worn out and I have to replace it soon, so I've been looking into aftermarket parts. I'm a daily driver in NYC, and I'm looking for an aftermarket part that's similar to the stock part.
People have reccommended a few that are good, but I'm told that they're very stiff, etc. Please recommend one that would almost feel the same as the stock part.
Thanks guys!
Fujitsubo Turbo back exhaust
Greddy bov
Hallman MBC @ 19psi
HKS ground kit
Apexi intake with induction box
Samco intercooler & radiator piping
Dyno flashed
Old Aug 12, 2006 | 11:33 AM
speedracer2169's Avatar
the only thing i can tell you is to search and if you want a better idea why not ask any of the local guys to just drive it in a parking lot to feel the stiffness of the clutch. what may be stiff to you probably isnt for someone else
Old Aug 12, 2006 | 11:53 AM
anikisama's Avatar
the reason is,, any of my local guys don't mods alot.
Mine is the most moded evo so i'm asking to you guys.
and, Yeah I did search of course but there are soooooo many posts about cluch.. about performance, stage x something like this.
and I can't even find out my answer at all. can you tell me what should I read?
Old Aug 12, 2006 | 01:10 PM
lcakes05's Avatar
i wouldnt get a cheap act i have seen them ruin peoples transmissions
Old Aug 12, 2006 | 02:27 PM
gsrboi80's Avatar
^ Dude ACT clutches are some of the best street clutches on the market. Not the best for racing but daily driving they work very well. As far as ruining transmissions thats the dumbest thing Ive ever heard no offense . The only thing about act clutches in an EVO is that you will have to adjust your clutch pedal properly to avoid any high rpm lockout.
Old Aug 12, 2006 | 02:33 PM
WrX Kila's Avatar
IF YOU WANT A GOOD CLUTCH THAT WONT HURT YOUR POCKETS....... ACT!!!! ACT!!!!.
I had mine in for about 2 1/2 years now. No problems. I changed the disk when I was getting my trannny rebuilt. I will buy another one hands down, no questions about it.
Old Aug 12, 2006 | 02:37 PM
lcakes05's Avatar
don't get cheap when it comes to your clutch. i had a friend w/ an act that screwed up his tranny. ive never had one but i sure as hell would not buy one after that happened to my buddy
Old Aug 12, 2006 | 02:39 PM
4TUN8's Avatar
Act HDSS, I run it, its a great all around clutch, little stiffer then stock but not much.
Old Aug 12, 2006 | 02:42 PM
gsrboi80's Avatar
Eaither your friend does not know how to drive or whoever installed it did not do so properly. Just you saying that the ACT clutch f^%$ed up his trans is not proof enough. What exactly happened that he can prove. How did the clutch destroy the tranny. Sorry I dont believe it
Old Aug 12, 2006 | 02:51 PM
lcakes05's Avatar
i just heard from him about his act experience and decided to stay away from that brand of clutch i dont have any proof of anything nor do i need it to prove anything to you, if you have a good experience with that product great. i will stop bad mouthing the clutch since i have no experience w/ it but that does not change my opinion
Old Aug 12, 2006 | 02:54 PM
gsrboi80's Avatar
Cool . Didnt mean to be offensive just wanted to disprove that the clutch was the actual culprit of your friends trans breaking.
Old Aug 13, 2006 | 07:04 AM
olsookie's Avatar
Lightbulb
Exedy All the way...
Stage 1 should be good for the street
Road Racing
OEM Stock Clutch @ the Flywheel LBS-FT = 278
Stage 1 @ the Flywheel LBS-FT = 415
Stage 2 @ the Flywheel LBS-FT = 480
OEM Stock Clutch @ the wheels LBS-FT = 250
Stage 1 @ the wheels LBS-FT = 374
Stage 2 @ the wheels LBS-FT = 432
OEM Stock Clutch @ the Flywheel LBS-FT = 223
Stage 1 @ the Flywheel LBS-FT = 330
Stage 2 @ the Flywheel LBS-FT = 385
OEM Stock Clutch @ the wheels LBS-FT = 201
Stage 1 @ the wheels LBS-FT = 297
Stage 2 @ the wheels LBS-FT = 347
Exedy is the way to go man!!
Last edited by olsookie; Aug 14, 2006 at 07:46 AM. Reason: fat fingered a number...
Old Aug 13, 2006 | 07:56 AM
DrSmile's Avatar
Opinions are like ..., everybody's got one. ACTs are great clutches, the only way an ACT clutch could possibly cause your trans to blow up is if it kicks one of the springs on the pressure plate through the bell housing, which I have seen happen, but I believe ACT fixed that problem.
