losing power between 3.5 and 4k!?!?
Old Aug 16, 2006 | 09:13 AM
sirloin1219's Avatar
hey guys just wanted to see if any of you guys could shed some light on this. im not sure if it is a possible boost leak of maybe even my clutch just going bad...
but when i accelerate between the rpm range of 3.5k and 4k i lose power but the boost doesnt drop. then once i pass 4k i feel the power come back. i think it's just my clutch going bad. but what you guys think? it happens in all gears.
thanks
Old Aug 16, 2006 | 09:23 AM
joeymia's Avatar
thanks
Could be the clutch or your engine is knocking. That RPM range is when you reach peak torque which is usually were most of the knock occurs. Are you tuned?
Old Aug 16, 2006 | 09:24 AM
yea i have a dynoflash. havent done anything to the car since my flash so im not sure what could have caused it.
Old Aug 16, 2006 | 09:25 AM
joeymia's Avatar
how much boost are you running?
Old Aug 16, 2006 | 09:27 AM
Rnm's Avatar
Rnm
Sounds like your clutch is slipping.
Old Aug 16, 2006 | 09:30 AM
emagdnim8's Avatar
+1 for slipping clutch
do a 5th gear pull on the highway. it'l slip then grab
Old Aug 16, 2006 | 09:33 AM
yea it does it in 5th as well..so i guess it's my clutch...im running 20lbs boost. but i rarely every go full boost to save gas haha. but yea. does it in every gear including 5th
Old Aug 16, 2006 | 09:47 AM
51's Avatar
51
Actually the higher the gear you are in the more it will do it due to more load. I bet you it will not do it in 1st gear. Mine started in 4th gear then after driving it for a while it starts happening in 3rd gear as well then finally in 2nd gear. Traded it before it got even worse.
Old Aug 16, 2006 | 09:56 AM
51, sounds exactly what is going on with mine. first noticed it in 4th then 3rd, now 5th..guess it's time to spend more money on the money pitt!
thanks guys!
Old Aug 16, 2006 | 09:58 AM
deegaw11's Avatar
it's your clutch...you usually feel the slipping when you hit boost
Old Aug 16, 2006 | 10:25 AM
Stew's Avatar
When your clutch is slipping your RPM's will increase, and then drop when the clutch catches. If your clutch is the problem, you will probably notice your RPM's act like:
3000-3500-4000-4500-4000-4500-5000-5500....
If the RPM's drop with the power, your engine is pulling timing, you could be hitting fuel cut, etc.
How many miles on the Evo, what are you using for a boost gauge, etc?
Old Aug 16, 2006 | 11:01 AM
i have 16k now on the clock, and im using a defi d boost gauge..it's pretty accurate to my knowledge from when i got it tuned. but from what your describing really does sound like my clutch, and from what i read..this is about the time my clutch starts crapping out on me.
Old Aug 16, 2006 | 11:47 AM
Warrtalon's Avatar
Yep, clutch.
korizmo
Apr 27, 2012 11:41 AM
pennies_hatchie
May 24, 2010 06:24 PM
tripperfx3
11
Oct 8, 2007 04:45 PM
Evoluvin
18
Jan 2, 2007 10:26 AM
mensaman
Apr 20, 2005 10:41 PM
