Smaller PVC valve?
Old Aug 27, 2006 | 02:32 PM
Varrius's Avatar
Smaller PVC valve?
http://www.z1auto.com/prodmore.asp?m...ne&prodid=1203
This says it requires a smaller PVC valve, or elimination of it all-together? What do they mean by this? Also, what is a PVC Valve? And how do I eliminate it or make it smaller?
Old Aug 27, 2006 | 02:50 PM
Varrius's Avatar
Anyone? =(
Old Aug 27, 2006 | 02:51 PM
EvoDan2004's Avatar
well dont they sell it. it says 12 bucks for it and 299 for the cover. just get it if it is needed.
Old Aug 27, 2006 | 02:53 PM
EvoDan2004's Avatar
and the pvc valve is for letting air thru and no oil. it is like a check valve. but you dont realy need it. i got a catch can on mine so the oil that blows by dont go back into my intake manifold. keeps it nice and cleen
Old Aug 27, 2006 | 03:05 PM
Varrius's Avatar
The $12 is for the shipping cost. So, if I got an Oil Catch can, I could just install it with the valve cover?
Old Aug 27, 2006 | 04:01 PM
EvoDan2004's Avatar
o opps ok well you can use it as it is from the factory or get rid of it all togeather or just put a cc there like i did. but still does it come with the pvc or no. if not the 8 pvc wont work with the 7 valve cover
Old Aug 27, 2006 | 06:03 PM
spm1024's Avatar
not that it matters, since 90% of the population says the same thing, but it is a PCV VALVE not PVC. PCV = positive crankcase ventilation.
Old Aug 29, 2006 | 11:22 AM
barneyb's Avatar
For normal driving I'd want a PCV valve. It might make the intake manifold dirtier but the engine will stay cleaner. For high speed track driving the engine will start to pump a lot of oil out through the PCV valve, I've heard as much as a quart an hour. So then a catch can makes sense. Also, without a PCV valve you become a polluter.
Old Aug 29, 2006 | 11:29 AM
ex-honda's Avatar
I heard that the EVO 7 cover doesn't really fit well with the 8's Some had problems with oil leaks not sure why though because it looks the same except for the raised "Evolution" name.
Boosted4
Jul 21, 2014 02:48 PM
raiceboi697
Jan 29, 2012 09:00 AM
aleEvo
Dec 30, 2009 04:42 PM
ralliart 04 21
Dec 18, 2006 05:22 PM
kreionic
10
Aug 1, 2006 02:31 PM
