No heat need help.
Old Sep 6, 2006 | 02:43 PM
unknown2's Avatar
Question No heat need help.
I recently had a mail in flash done and i put in a ralliart thermostat and now i have no heat at all. Can anyone give any ideas where too start try to problem solve.
Thanks in advance.
Old Sep 6, 2006 | 02:56 PM
slow_evo's Avatar
Sounds like your T stat is stuck open.
Old Sep 6, 2006 | 03:09 PM
revvin9k's Avatar
Or air in the system.
Old Sep 6, 2006 | 03:30 PM
unknown2's Avatar
There is no air in the system, tomorrow i'm going to put the stock one back in and see if thats the case.
Thanks for the help guys
Old Sep 6, 2006 | 03:34 PM
spudlus's Avatar
If you have no temp reading at all that sounds sensor related. Did you reconnect the plug to the sensor? Is it damaged? Even if the thermostat is stuck open you would get a reading after a while and MAYBE overheating issues since the coolant isnt being "cooled" effieciently.
Old Sep 6, 2006 | 03:37 PM
spudlus's Avatar
If you must test, you can do a static test by heating the thermostat to see if it opens at the particular temp.
If I remember correctly, you can use a heat gun or "boil" the thermostat until it opens then cool it to close.
Old Sep 6, 2006 | 06:48 PM
caligula's Avatar
air in the system or defected thermostat.
Old Sep 7, 2006 | 07:16 PM
unknown2's Avatar
Here is a pic of the Ralliart one.
Here is a pic of the stock one, If you look at ^ the bottom of the Ralliart one it blocks the passage for the Heater core.
Hope this helps other people later down the road.
But i will put it back in the spring time again.
Old Sep 9, 2006 | 01:00 AM
unknown2's Avatar
Ok, I still have no heat after i put the stock one back in......I have no clue were to start from now to trouble shot...
Old Sep 9, 2006 | 01:03 AM
unknown2's Avatar
The fans blow just not warm air at all. The flap opens up also.......
Do you think if the ECU is not in the metel clip that it might bump something from it opening up.......
Old Sep 9, 2006 | 03:49 PM
barneyb's Avatar
There are only three possibilities: air in the engine, bad thermostat or cable off the underdash heater box. I've used the procedure given in the service manual for refilling the cooling system and it works. Second, boil the thermostat to determine the temperature at which it is opening. If it starts to open before 176 F, then you will get little heat. Make sure you are not installing it upside down. Finally, check that the cables are moving the controls on the heater doors.
Old Sep 10, 2006 | 12:49 PM
firehawkta2000's Avatar
Another thought....the ECU controls some of the gauge cluster in these cars. Maybe something went bad in the new tune that controls the input from the temp sensor output for the coolant gauge?
Old Sep 10, 2006 | 12:52 PM
evo542's Avatar
does the temp gauge read normal?
iJHolmes
Jan 14, 2013 07:45 PM
Oziel
Oct 7, 2012 04:10 PM
Graphic
Pacific Northwest
Jun 4, 2012 03:23 PM
ralliart 04 21
Jan 15, 2007 10:41 AM
Mistasparkle
Mar 6, 2004 11:39 AM
