to much boost?
Old Sep 7, 2006 | 10:24 PM
sparky's Avatar
Originally Posted by APEX1
I have a warrtalon stg1...im running 94 oct at 20 psi...I want to turn up the boost ... but only if its safe...cause I was told that if I go over 20 psi im like losing 15 hp cause that retards the timing.?help
On an '05 with 94 octane..... you should be good to 21.5# in the winter, maybe even a tad more...no problem, assuming everything is in proper working order. You should gain, not lose, 15 horsepower. Your ECU won't retard the timing unless it senses engine knock. Where is Warrtalon...are we here all alone?
Old Sep 8, 2006 | 01:12 AM
Ang Wen Yan's Avatar
The EVO 9 can run 24psi on 94 due to revised cooling passage and a better knock sensor
Old Sep 8, 2006 | 02:40 AM
Evo_Jay's Avatar
It has better coolent passages in the head (then the VIII), allowing for more aggressive tuning.
I'm pretty sure it has the same knock sensor has the VIII. But I think the IX ECU has better knock control.
Old Sep 8, 2006 | 02:05 PM
EJEvo's Avatar
Last I knew he was in timeout.
Old Sep 8, 2006 | 02:38 PM
-=SPECTRE=-'s Avatar
Please add Time Cube to your kook museum!
Old Sep 8, 2006 | 04:06 PM
EJEvo's Avatar
It ain't my museum, I'm just a visitor...
And when, exactly, does this "Time Cube" come and visit you?
Old Sep 8, 2006 | 05:51 PM
kapolani's Avatar
I wouldn't run 24 psi unless you were tuned for it. I wouldn't even run 23...
I'd say you're safe @ 22psi.
Of course - you should datalog to see what your timing looks like. If you can check your knock sum.
Old Sep 10, 2006 | 05:50 PM
zeus1's Avatar
i have a defi gauge..mbc and ecuflash tune i will see 24psi spikes..holds to 20 or so at redline (this is probably more like 23 or so to 19 since the defi reads high)...my car was dyno tuned for this. as stated above too much boost and you will get throttle cut to prevent engine damage
Old Sep 11, 2006 | 02:16 PM
Joeekrub's Avatar
can the STOCK turbo run 28lbs of boost on a high octane, well well tuned car? or will blow up after 100 miles
jacfumo
Lancer Engine Tech
19
Dec 10, 2008 03:08 PM
80210
May 26, 2007 02:15 PM
EVIL_EVO_VIII
Jun 21, 2005 07:58 PM
agent5568
Lancer Aftermarket Forced Induction Tech
28
Dec 22, 2003 07:40 AM
EvoDaWayToGo
13
Apr 9, 2003 10:33 AM
