EVO's Slow Clutch Take Out
Old Sep 16, 2006 | 12:15 PM
thisxguy's Avatar
get your car tuned. whoever tunes your car will make your turbo spool sooner and smoother across the powerband...making your car feel a lot faster
Old Sep 16, 2006 | 05:15 PM
PTevo's Avatar
If you want to Jump off the line on a regular slow launch, get the Tilton clutch. Clutch engages very quickly and you are moving instantly. Of course, other driveability issues with tilton, so pick your poison.
Old Sep 16, 2006 | 07:29 PM
11SECEVO's Avatar
What other issues???
Old Sep 16, 2006 | 07:50 PM
adamhw's Avatar
You may want to try using the e-brake, and releasing it when you launch. It may help take up some slack in the drivetrain when you get going.
Old Sep 16, 2006 | 07:55 PM
fusionchicken's Avatar
i can take off pretty quickly from a stop...just stomp the gas and let off the clutch at a higher point than u would usually.
now if we're talking a mini-launch...then yea, the Evo has no low end torque, and a V8 or hell even a V6 will be much better for that.
Old Sep 16, 2006 | 08:49 PM
occultworks's Avatar
I don't see how this is a problem. I think you're just trying to drive it like a rwd v8. Try driving like it's a slow ff. A few more revs, and a little slippage.
Old Sep 16, 2006 | 08:54 PM
hondafan's Avatar
try removing the restrictor pill, like in this write up. it makes a world of difference, and saves the clutch. mitsu puts it in there for people that like to dump the clutch instead of slipping it on a hard launch. good luck.
http://evomoto.com/tech_info.php?tPa...507d910ef56200
Old Sep 17, 2006 | 04:39 AM
11SECEVO's Avatar
THANK YOU!! Thats most likely EXACTLY what I need to do....Great Write up too by the way
Old Sep 17, 2006 | 09:04 AM
FJF's Avatar
FJF
I thought of you this morning as I took my Sunday spin. Usually, everything happens almost unconsciously, but today I kept an eye on the tach. If you rev up to ~2500-3000, slip in the clutch and then add throttle smoothly as the clutch grabs, the Evo will accelerate at a good clip without a need for a full launch. FWIW, removing the restrictor pill will make the clutch engage more positively, but you'll still need to slip it for a relatively quick take-off.
Old Sep 17, 2006 | 09:13 AM
dubbleugly01's Avatar
It's a turbo car and has no torque down low. With a 8:1 compression, you need the turbo to make any power. It's the nature of the beast, there's nothing wrong with your car. That's just the way it is. Is this your first turbo'd car? The only way around it is to get your rev's up, and slip the clutch more than you're used to.
Old Sep 17, 2006 | 03:41 PM
Rice King's Avatar
Buy more stuff, get a stainless steel clutch line, (100 bucks) at 2500 you can feather out the clutch with more control and nice an slow. still pretty touchy tho
Old Sep 18, 2006 | 12:10 PM
trinydex's Avatar
http://www.socalevo.net/index.php?op...6&topic=2493.0
Old Sep 18, 2006 | 12:22 PM
DRFTKNGG's Avatar
Originally Posted by f-dub
Removing the restrictor pill might also help.
+1!
Exactly the problem! Remove this...enjoy!
Old Sep 18, 2006 | 12:44 PM
Fusion7's Avatar
ITs a 4-banger with AWD.....its not going to take off that fast without launching it.
mrmiller
Mar 14, 2016 04:06 AM
Sarich5
Apr 16, 2009 04:31 PM
ch3njiawei
May 10, 2008 11:57 PM
Noize
15
Apr 28, 2005 10:24 AM
spinhouse11
44
Apr 29, 2004 12:16 PM
