DUMB MBC Question?
Old Sep 19, 2006 | 10:16 AM
Evolution2003's Avatar
DUMB MBC Question?
I just got Buschur Stages 1+2, but the boost gauge was broken in the mail, now i had to send it back and i will be putting all the parts on my car tomorrow.....My question is what do i set my MBC at without the boost gauge-will it run base line boost with it shut off and is it 1 revolution per psi?
Thanks in Advance
Old Sep 19, 2006 | 10:19 AM
elhalisf's Avatar
set it to the lowest setting, which will run 11 psi. it is not a psi per revolution.
Old Sep 19, 2006 | 10:20 AM
confusionisbad's Avatar
I would just not hook it up until you get your boost gauge. Its easy enough to hook up at the same time as your boost gauge. Better safe than sorry.
Old Sep 19, 2006 | 10:28 AM
kreionic's Avatar
Definatly not. Be smart about it and what to do the mbc till you get your gauge in. The install on the mbc is very easy and won't take up much time
Old Sep 19, 2006 | 10:42 AM
03redtype-s's Avatar
Very true i would just wait and do them at the same time. just incase the mbc may spike a huge amount for some reason atleast you would know
Old Sep 19, 2006 | 10:47 AM
Ev0ikon's Avatar
That's ok. Jsut DO it! Then put the condom on later. :P
Old Sep 19, 2006 | 10:49 AM
FiftyFive's Avatar
definatley wait for the gauge, better to be safe than sorry
Old Sep 19, 2006 | 10:50 AM
saiyanzzrage's Avatar
if its unscrewed all the way, you would be boosting to wastegate..an option until you get the gauge in the car
Old Sep 19, 2006 | 11:09 AM
ShtrMcGavin's Avatar
Just buy a boost gauge they even sell autometer ones at autozone... $50 well spent
Old Sep 19, 2006 | 11:17 AM
Ev0ikon's Avatar
Autometer SportComp is actually a very nice gauge for the money.
Old Sep 19, 2006 | 11:38 AM
evolrobert's Avatar
how long does it take to install a mbc?
Old Sep 19, 2006 | 11:51 AM
30 mins if you take your time and dont really know what your doing
Old Sep 19, 2006 | 12:03 PM
wirespeed's Avatar
u should just wait till u get the gauge...so u can install both at once. saves time
but if u must u can install the mbc and have it unscrewed very loose or just dont boost at all then u would have no problems
Old Sep 19, 2006 | 12:22 PM
SteveosEvo's Avatar
Just wait until you get the guage in. What if you put the mbc in and you dial it wrong or it malfunctions. You will be very sorry then. Just get a new gauge and put everything in at the same time. Better safe than sorry.
Old Sep 19, 2006 | 01:31 PM
travman's Avatar
you need the boost gauge to adjust the mbc, until you have the boost gauge leave it stock its not hurting anything.... dont be that guy
