jdm mr makes my car run like crap.
Old Sep 21, 2006 | 04:16 PM
deegaw11's Avatar
my idle is horrible with this dv. my car died on me once when i put it on neutral to come to a complete stop. i changed my plugs and i put my boy's 06 mr dv on just to see was there something wrong with mine and it's still the same. rpm sometimes drops to 300 and then goes back to normal. when i put the plastic dv back on my car runs better. why is that?
Sap12687's Avatar
are you putting it on backwards?
Old Sep 21, 2006 | 04:17 PM
kreionic's Avatar
it sounds like its in backwards. Same thing happened to a buddy of mine
Old Sep 21, 2006 | 04:18 PM
deegaw11's Avatar
nope i dont think so..the nipple suppose to be facing up right? the top of the dv suppose to face sideways and not up right? im sure i installed it right.
Old Sep 21, 2006 | 04:21 PM
gsrboi80's Avatar
Bottom port goes to the UICP side port to the intake
Old Sep 21, 2006 | 04:23 PM
Sap12687's Avatar
is it broken?
Old Sep 21, 2006 | 04:26 PM
gregfromblur's Avatar
Hmm... well if you say its not backwards, then it shouldn't be.
Check all your vac lines.
Make sure everything is tight.
Can you push the DV open with your finger super easy? its weird that you tried two IX valves, and they both gave you the same result. makes me thing the problem is else where?
Try throwing your stock DV back on, and see if the problem is still there.
Old Sep 21, 2006 | 04:39 PM
deegaw11's Avatar
my car runs better with the plastic dv..idles smoother and boost feels better.
Old Sep 21, 2006 | 04:45 PM
hmm. thats weird. Well.. since you tried Two different IX DV's...<Br>
i suppose you're only other option would be to switch over to a Forge or somthing?
Old Sep 21, 2006 | 07:05 PM
k270kmh's Avatar
this sounds strange since my jdm mr valve improved my boost response and idle is just perfect as before
Old Sep 21, 2006 | 07:11 PM
Theibault's Avatar
Just my 2 cents, but my Evo almost...ALMOST...stalls every time I go from rev into gear.
Old Sep 22, 2006 | 11:30 PM
eponti's Avatar
are you venting it out in the atmosphere?if so it will stall on you
Old Sep 22, 2006 | 11:53 PM
pacent's Avatar
Maybe the JDM MR bov is leaking on you or defective. Have you tried to do a leak test?
Old Sep 23, 2006 | 01:15 AM
Warrtalon's Avatar
He tried 2 separate ones, so it's not defective. There is a definite problem, but it makes no sense that the JDM MR/EVO IX DVs would cause these problems.
