Video: 2-step problem
Old Sep 22, 2006 | 07:56 PM
jdmevo8313's Avatar
Registered User
Originally Posted by EvoRicer
Are u flashed for it? If not how are you doing it?
nope, no flash, it stock. You have to be completely stationary with the clutch in and in first with revinng to 5K. I build about 6-7psi.
Old Sep 22, 2006 | 08:20 PM
DreamLike1's Avatar
Originally Posted by 3SgteGuru
Just A Question Wouldn't the "Stock 2-step" be a Rev-limiter and not a 2-step
This is a 2-step I believe http://video.google.com/videoplay?do...launch+Control
I think This is What your Aiming For
OMG.... more video's of that second car. That looks like a possible 10 second car????
Old Sep 22, 2006 | 09:33 PM
Crufty Dusty's Avatar
It's ignition cut. You flood the cylinders with too much fuel if you hold the throttle down for too long. That's why it drives like ****.
Old Sep 22, 2006 | 09:41 PM
brokenRS's Avatar
okay i am sorry but can someone fill me in in this "2 step" launch control. does this come with the 2003 evo8? or only 05 and so on. sorry for off topic
Old Sep 23, 2006 | 12:54 AM
mike1023's Avatar
It became standard equipment for the 05 model year. 03 and 04 Evos don't have it from the factory, but I believe you can get it with a flash or engine management (UTEC, AEM EMS, etc).
Old Sep 23, 2006 | 02:16 AM
Evo_Jay's Avatar
This^
or
Some say that the knock count goes up kinda high if you hit the 2-step too hard and/or hold it for to long. Maybe your holding it to long, get a big knock count and having timing pulled like crazy.
Old Sep 23, 2006 | 02:28 AM
vegasboy301's Avatar
mine does the same thing sometime. i think it is just the engine being flooded with fuel
Click here to see Video
Old Sep 23, 2006 | 03:50 AM
Rez90's Avatar
the car took a poop before it got going
Old Sep 23, 2006 | 06:12 AM
BURNALL_4's Avatar
i build like 15psi but mines set at 6k
Old Sep 23, 2006 | 11:52 AM
mike1023's Avatar
humm is that like alky thats why its shot fire
Old Sep 23, 2006 | 01:19 PM
no no alky...
Old Sep 23, 2006 | 01:27 PM
JeffMas1587's Avatar
i just orded the WT package from buschur and opted to get the test pipe. when i use the 2 step will i also shoot out a flame? will i have a flame any other time while driving hard or coming out of a hard boost?
Old Sep 23, 2006 | 07:04 PM
EvoDriven's Avatar
wait you can do 2-step on a stock 05? How?!
Old Sep 23, 2006 | 07:30 PM
EvoTio's Avatar
This very interesting info. I was just at the drag strip today and used my 2-step for the first time. My first launch was exactly like your first vid, I had major bog and a 2.10 sixty foot. I must have been holding my 2-step too long. My second attempt was better, but only a 1.80 60 foot. I may have still been holding it too long. After watching your vids, I'm definitely going to hold it for a much shorter time before the launch and hope for some 1.70-1.65 sixty foots like I have been doing before I had a 2-step.
Old Sep 23, 2006 | 07:40 PM
mack4477's Avatar
ok, now i have an 03, with launch control added into the ecu. i held mine a little once, to see what max boost was going to be. after about 4 seconds, it let go and the rpms just climbed beyond the 6k. should it let go like that instead of holding on forever??
http://vids.myspace.com/index.cfm?fu...oid=1115006556
