Anyone have a Stock Evo thats flashed & tuned?
Old Oct 12, 2006 | 02:29 PM
  #31
diegoalunan's Avatar
30-50 hp gain on stocks.. where can i get this and for how much?...
i shouldve flashed first before doing my audio system,, had it done 2 days ago.. but im happy with it, just waiting on my focal speakers and my audio/video set up is complete
Old Oct 12, 2006 | 02:32 PM
  #32
stingerbtry's Avatar
Originally Posted by EVOBrad
So they dropped the boost from 20.3PSI all the way down to 14PSI on the later model IX's? Do you know when this cutover occurred? (I just bought my new IX a couple of weeks ago, so I'm guessing I probably fall into the latter group.)
Not sure exactly when. I bought mine a few months ago and mine was one of the victims so I bet yours is as well. Just check your boost gauge if you have one and if not install one. Mine was barely going past 1 bar peak/steady/anytime before the mbc was installed with new lines.
Old Oct 12, 2006 | 02:33 PM
  #33
Go see Andy at speedelement in fremont. You won't be disappointed.
Old Oct 12, 2006 | 02:55 PM
  #34
Boost Limit's Avatar
I had Andy from Speed Element and Paul at EIP Racing (they both use EIP's Mustang Dyno) take care of the tune.
Car is pretty much stock...except for a Works panel filter. I had a mbc installed on the car since apparently later IX's run much lower boost. I think I was spiking at around 21psi...and tapering to around 16.
After the flash I was putting down 275whp / 290tq with 23 psi tapering down to 19. This is also a very conservative tune. I don't know the specifics but there was 0 knock count in the upper rpms. They said aggressively tuned the car could put more than 280whp out from that setup at the cost of overall reliability.
Old Oct 12, 2006 | 04:30 PM
  #35
FASTEVO8's Avatar
Yes and no I guess. Mine didn't have a restrictor pill so raising the boost with ecuflash did nothing for me but yes the values are there and as long as you have the correct pill(s) or get them installed then you should be fine. I know Works and probably some others change out the pill and do it with the flash. It's much easier to just get a manual boost controller and do it that way though IMHO.
Thanks for the clarification. I'm pretty sure I will be getting an APEXi AVC-R so I guess I will use it. It will be nice to be able to change boost from inside the car.
Old Oct 12, 2006 | 05:09 PM
  #36
ernald711's Avatar
even though the numbers aren't really impressive, i'd still get one if i was stock just to remove the launch rev limiter, high boost taper at high rpms, and just be able to rev higher.
the extra 5 or more ponies are not worth getting scared everytime you mash the pedal. would be nice though, but i would never compromise that with reliability.
Old Oct 12, 2006 | 05:52 PM
  #37
FASTEVO8's Avatar
[QUOTE=ernald711]even though the numbers aren't really impressive, i'd still get one if i was stock just to remove the launch rev limiter, high boost taper at high rpms, and just be able to rev higher.
Why would you want to rev higher if our cars don't make power up that high???
Old Oct 12, 2006 | 06:05 PM
  #38
evo8kiko05's Avatar
TUNED BY TUNING TECHNOLOGIES!! ECUFLASH 276hp/282TQ 91pump 20lbs boost.
Old Oct 12, 2006 | 06:37 PM
  #39
tirbolag9's Avatar
[QUOTE=FASTEVO8]
if you're a road racer, you would want to rev high in order to stay in boost and/or to stay in the power band during the upshift during a turn when needed.
if you're dragging, then the higher rev limit would be pointless, but fun nonetheless.
Old Oct 12, 2006 | 10:21 PM
  #40
TurboIX's Avatar
Mine spikes to 1.5 and holds 1.3.. Completely stock. I think that's close to 22psi am I correct?.
Old Oct 12, 2006 | 11:05 PM
  #41
Mystique's Avatar
Not the later models. Apparently the early IX's were spiking at ~23 psi and Mitsu decided to remove the restrictor pill in the boost line on the later IX's which drastically dropped the boost level.
So does that mean the later IX's are slower than the older IX's?
Old Oct 13, 2006 | 06:39 AM
  #42
PessimiStick's Avatar
Stock, yes.
Old Oct 13, 2006 | 07:10 AM
  #43
thetox's Avatar
1.5 bar x 14.5psi(1 bar) = 21.75psi
Old Oct 13, 2006 | 07:50 AM
  #44
Ryan Bell's Avatar
Originally Posted by Iceplant18
20.3 psi is the peak boost which it hits around 3500 rpm. It tapers down to around 14-15 psi on the way to redline. What was mentioned earlier is using a MBC to prevent the boost from tapering down so that it hangs at 20 psi all the way till redline if not to a higher psi.
That makes way more sense. Thanks.
Old Oct 13, 2006 | 07:53 AM
  #45
Ryan Bell's Avatar
So who are the top tuners in your opinion?
How does Buschur's flash stack up against Andy's tune, or Ecutek, etc?
