Put on HKS Suction intake -- big problems w/ car. HELP!
Old Oct 19, 2006 | 10:22 PM
  #61
r0ck3r's Avatar
i have a dc sport catback that i need to throw on, i will eventually get MBC, and i need to get the reflash now aparently :P
Old Oct 19, 2006 | 10:28 PM
  #62
Spec'd's Avatar
It's easier to install all your modifications now so you can tune it afterwards.
At least you can still install your catback for now.
You can also tune incrementally as you add your modifications.
Old Oct 19, 2006 | 10:47 PM
  #63
r0ck3r's Avatar
how does the mail flash work? i need to take out ecu and send it to someone to get it flashed? or do i actually need to get a TUNE just for the intake, lol ... or will the flash work
Old Oct 19, 2006 | 11:00 PM
  #64
r0ck3r's Avatar
well i just connected the battery again and started it up and it runs as crappy as it did before, just idling. didnt bother to drive it around
Old Oct 19, 2006 | 11:02 PM
  #65
Spec'd's Avatar
One thing great about the Evo is that there is so many choices.
Yes you will have to remove your ECU for mail-in flashes.
If you get the tatrix cable, you can get an email flash and upload
it via your OBDII port.
Depending on who you ask will depend on which vendor is prefered.
This would pertain to both the mail-in and email flashes.
Old Oct 19, 2006 | 11:07 PM
  #66
Spec'd's Avatar
At this point, I would just put it down and wait until daylight.
Sometimes it's better to get a fresh perspective later on.
I have to wonder if your problem is BOV or boost hose related.
Old Oct 19, 2006 | 11:08 PM
  #67
r0ck3r's Avatar
i dont think ill be able to tell whats goin on with it tomorrow either.
i might try putting the stock intake back in tomorrow after work, except its going to be night time when i get off of work again and see how it runs then...
Old Oct 19, 2006 | 11:16 PM
  #68
Spec'd's Avatar
Best thing to do is get a good night rest for now and try not to stress over it.
You'll get it fixed sooner or later. I mean it's 2:30am on your side of the country.
Old Oct 19, 2006 | 11:17 PM
  #69
Jon H's Avatar
And you're absolutely sure that all the IC pipes are connected properly? The symptoms sound like a d/c'd IC pipe somewhere. Check the elbow at the throttlebody, the connection at the turbo and diverter valve area.
Old Oct 19, 2006 | 11:35 PM
  #70
r0ck3r's Avatar
i never touched any of the intercooler pipes ... but i will check and see if anything came loose somehow, but i 100% doubt it.
Old Oct 20, 2006 | 12:14 AM
  #71
DontRevMe's Avatar
dear god how do people learn on this forum.
Old Oct 20, 2006 | 12:24 AM
  #72
TogueMonster's Avatar
Originally Posted by DSMEVOLUTION
Man I'm so suprised 99% of you guys talk out of you butt hole. Putting an intake on does require a tune but that will not make his idle f_____p up. Do some research before posting.... please!!!! You must have hooked something up wrong. Try throwing the stock air box back on and see if it still does it. You can drive around all you want with an intake on without a tune but you'll lose power and it would be a good idea not to get on it at all.
Umm, no pal. YOU should take YOUR OWN advice because I am speaking from experience and what I have heard from others. Yes, I know how to install a fcking intake. I've installed my own lowering springs and am currently doing a clutch install. But thanks for nothing. Jerk!
Old Oct 20, 2006 | 01:00 AM
  #73
Spec'd's Avatar
Now Now lets behave like gentlemen here.
Old Oct 20, 2006 | 06:53 PM
  #74
r0ck3r's Avatar
anyone come up with some new advice? if the honeycomb isnt exactly the way it was from the factory will it caues it to mess up? i hit it a little bit with my vice grips, and i will try to take a pic of it and post it here for reference
Old Oct 20, 2006 | 06:58 PM
  #75
Spec'd's Avatar
That doesn't sound promising about the MAF.
Hopefully you didn't hurt the actual sensor part.
Why are vicegrips anywhere near the MAF ?
