Fixing Turbo Help! Urgent!
Old Oct 20, 2006 | 12:26 PM
J8dailo's Avatar
i just bought a 20g-9-5 from a member on this board and i just got it.. it turned out that its missing a wastegate and the connect where the wastegate arm and the flapper opener is bent... i tried bending it back straight but im not sure if thats safe... my car is in shop waitin for turbo and i got a bad turbo from user on this forum... i dont have time to get another one but would bending the connecting section back straight be a problem?? and plus... would i be able to swap an evo 8 wastegate to and evo ix wastegate.. the 20g is missin a wastegate too...
Old Oct 20, 2006 | 12:30 PM
honda-guy's Avatar
take a picture of it and post it. it would help if we could see how bad it is. you should heat it with a torch before bending it.
Old Oct 20, 2006 | 12:36 PM
J8dailo's Avatar
i dont have a camera... i bent it back with a wrench... it seems pretty straight... the bent was about 20degrees i say.. it was hittin the turbine housing which isn't allowing the flapper to close all the way...
do you know if an evo 8 waste would fit on an evo 9 20g-9-5
Old Oct 20, 2006 | 12:38 PM
J8dailo's Avatar
it the flapper open and closes fine now but im not sure if its going to have an effect on it.. the bent was enough to prevent the flapper from closing.. it would only close about 1/2 way
Old Oct 20, 2006 | 12:56 PM
RoadSpike's Avatar
Maybe it was dropped and happened to hit that spot. Just give the whole turbine a good look over
Old Oct 20, 2006 | 03:09 PM
J8dailo's Avatar
the turbo is fine.. no shaft play... but the turbo is missing a wastegate
Old Oct 20, 2006 | 03:10 PM
kreionic's Avatar
Damn dude I would be a little ticked off at the seller if you didn't know about the problems
Old Oct 30, 2006 | 05:39 AM
EVOLVEU's Avatar
ive got a question(ive got a similar issue). when the arm the wga connects to is all the way down, is this more or less boost?
03evo4g63
Mar 29, 2009 02:02 PM
03evospeed
Oct 9, 2006 01:57 PM
Blue Evo 8
Aug 26, 2006 11:56 AM
Robbyh
Nov 17, 2004 07:43 AM
EvilDylan
14
Nov 10, 2004 07:31 AM
