Third gear grinding...
Old Oct 23, 2006 | 01:49 PM
evo637's Avatar
Originally Posted by JDMevoBOOST
Like I said...yes the car was meant to be driven hard, but that doesn't mean you have to abuse it. Punching the car into gear DOES NOTHING.....there is NO BENEFIT of doing this. You can shift just as quick by being smooth and light on the gear lever.
+1 the proper way is gear-neutral-gear, not jabbing.. Good luck hope everything works out.
Old Oct 23, 2006 | 03:53 PM
prj.evo's Avatar
Well I schedualed an appointment for wednesday. They said I should not worry about the warranty, the springs and filter will not void it.
I dont "jab" the car into gear. But I have only had it for 5 dyas, so perhaps the previous owner was a gear-jabber.
There is no possible way I could ignore this. I did not pay 26k for a car that I have to hold in neutral until idle during my 2-3 shifts. On the other hand, I dont want some dipsh*t mitsu tech working on my trans if it doesnt really need to be done...
Old Oct 23, 2006 | 03:55 PM
prj.evo's Avatar
Originally Posted by blackevoguy
mine just started doing this,usually when its really cold. but im gonna adjust the clutch a little remove the deal in the slave cylinder and call it a day.
What is this deal in the slave cylinder your talking about?
Old Oct 23, 2006 | 04:01 PM
prj.evo's Avatar
Originally Posted by dayf
The trans can be somewhat rough and will be notchy at random rpms. Both of my evos have done this. Does it consistantly do this? Will it grind at higher rpms too? Do you have a cone filter or a drop in? Drop ins are fine with all the dealers I've heard of. Might as well try to take it in if it is bothering you that much.
Not at higher rpms (although the only time Im really at hig rpms is when Im shifting a lot faster, and there is no signs of grinding then) It sounds just like trying to put your car into reverse without the clutch (but not quite as drastic). Sometimes I will shift and it wont do it, but then the next time it does.
Old Oct 23, 2006 | 04:04 PM
blackevoguy's Avatar
Theres a restrictor in the slave cylinder that slows the movment of fluid
http://evomoto.com/tech_info.php?tPa...cb2470ddc5d0ac
Old Oct 23, 2006 | 06:33 PM
mdacko's Avatar
Originally Posted by cableguy5752
I just bought mine a couple of weeks ago. And it has a slight grind going into third as well. Im not too worried about it though.
x2. got mine 11 days ago, noticed a slight grind/clunk going into 3rd, but i'm pretty sure its just me not used to the tranny yet, and something i need to correct in my shifting patterns. i doubt mitsu would do anything anyways.
Old Oct 23, 2006 | 07:01 PM
prj.evo's Avatar
I wish mine were that simple. But when I slide the shifter out of second and towards third, but stay in neutral, I can feel somethig strange going on in there, and then when it settles, I can move it into third with no problem. But by that time I am idleing down the road. But if I don't wait and just clutch in and shift, I can hear and feel it scratching the gear.
I am trying to make this as detailed as possible
Old Oct 23, 2006 | 07:05 PM
spdracerut's Avatar
check out a thread that I started, search for 'notchy tranny'.
Old Oct 23, 2006 | 09:32 PM
tripperfx3's Avatar
It seems most people have a slight grind going into 3rd or 2nd. Im going to replace my fluid with BG syncroshift hopefully by this weekend. Alot of people have fixed that slight grind by switching the synchroshift. Its supposed to be a thinner fluid, so it lubricates better, but doesnt offer the protection of the OEM fluid. Or like mentioned above replace the bushings and removing the restrictor pill.
Old Oct 24, 2006 | 08:58 AM
prj.evo's Avatar
Thanks your thread really did help out a lot..
Yea I am going to do all of that stuff, but first I am going to take it in and have it warrantied. Maybe I can get a free syncro out of them!!
Old Oct 24, 2006 | 02:12 PM
Evolved Monkey's Avatar
Hmm...do you really want the mechanics at the dealerships taking your tranny apart?? They could do more harm then good. Personally I wouldn't trust them to do a simple oil change on my evo.
Old Oct 24, 2006 | 03:10 PM
prj.evo's Avatar
^^Yes I have thought about the fact that they could possibly mess something up, but at the same time, I would most likley notice if something isn't right.
They will probably end up just replacing the gear oil anyways. That should mask the problem until I get the bushings, clutch line and new oil
Old Oct 24, 2006 | 03:15 PM
thisxguy's Avatar
i noticed that my car seems like it wants to grind 3rd a little when i go from 1st to 3rd (when i'm going downhill from a stop). when i throw it into 3rd it feels like it barely scrapes a gear or something. but its fine other than that.
i have a retarded 1st gear...sometimes it goes into gear retarded and feels like it scrapes the side abnormally
Old Oct 26, 2006 | 05:36 PM
mitsitech's Avatar
i must reply to this one......sorry i dont mean to highjack the tread, but im getting tired of some people on here bashing dealership techs without having a clue what they are talking about. believe it or not there some of us that really know what they are doing and are good at it. sorry to rant but im sick of some of the no nothing idiots that put all of us in one group without knowing about who we are
anyway.....i also wanted to tell you i have had luck with changing the gear oil to the BG synchro mesh and also changing out the stock clutch hose with the ss one
hope this info helps
keith
Old Feb 25, 2011 | 09:03 PM
boczo777's Avatar
i got problem with 3rd gear, before engine and trans was out it was just grinding, now i put everything back together, steel clutch hose, brand new stiff shifter bushings, fresh MT90 and....almost impossible to put 3rd in, i have to look for it, sometimes 1st another 5th is gonna get in, is there any chance to save it by changing into heavier oil or i have to replace synchros??
