Most Accurate Boost Gauge on the Market.
Old Nov 1, 2006 | 07:22 AM
  #106
GPTourer's Avatar
Originally Posted by 05 EVO RS
defi guages read high.....i won't put anything but autometer in my cars!!!
The two autometers I have /had in my DSMs seemed to read about 1-2psi high. One is a phantom and the other a cobalt. It didn' really bug me once I found out it was a common occurence and now I'm thinking $50 is apparently cheap - with the exception of the rule being the Stuart Warners.
Still, I'd rather have a boost gauge that reads a little high then one that reads too low.
Old Nov 1, 2006 | 08:09 AM
  #107
keviin's Avatar
Originally Posted by TTP Engineering
You cannot ASSUME that the dyno gauges are any more accurate than the POS autometer ones without knowing what pressure transducer they use, if any.
Example: Dynoing my car at fynetune in Miami, their POS G.E. pressure transducer stated I was running 38psi boost, a number that was at least 5psi too high.
maybe you didn't read my post correctly... i had it checked at 2 different reputable shops... gruppe-s and eip.... and I can assume that reputable shops have very accurate gauges/transducers.... these shops make their money off of us becuase we all assume that their equiptment is top of the line....
Old Nov 1, 2006 | 08:41 AM
  #108
AzBlackEvo8's Avatar
Originally Posted by _EVOled_
Thats what I thought along until I ran into a thread saying it was off by 1.5 psi and I believe Al or Warrtalon said that they are never recommended...
these guys are biased, if its not on their car, it's ****ty as hell.
I would rather get an EBC in your case.
Old Nov 1, 2006 | 09:31 AM
  #109
deadbeatrec's Avatar
let me ask u guys a question, how are u ever really going to know how accurate a boost gague really is? every single one could read something different, slight variations but variations non the less.
Old Nov 1, 2006 | 10:36 AM
  #110
Grog's Avatar
That's very true, and it's the main reason why it doesn't really make a lot of sense to spend a ton of money on a boost gauge expecting to buy higher quality. More expensive doesn't necessarily mean more accurate. This is true for any gauge for that matter. They're designed to be fairly accurate within a certain amount of error. Any extra money you spend is only for features...playback, peak warning, backlighting colors, etc. The Stewart Warner's are cheap, at least as accurate as the others, and the backlighting color can be changed by buying a new bulb for $3.
Some people may be convinced that the Defi's tend to read high...and maybe they do...but as long as it's always 1 psi higher than a MAP sensor reading, does it make a difference? If your gauge is consistent with itself, you can tune and the gauge serves its purpose.
Old Nov 1, 2006 | 11:28 AM
  #111
sonicnofadz's Avatar
Amen!
Old Nov 1, 2006 | 11:43 AM
  #112
Spooldyou's Avatar
+1 on Stewart Warner
Old Nov 1, 2006 | 11:49 AM
  #113
shivaswrath's Avatar
VDO is pretty accurate
Old Nov 1, 2006 | 12:16 PM
  #114
speedomodel's Avatar
Originally Posted by Mike01gsr
Guys DO NOT and I repeat DO NOT get SPA gauges. I loved these gauges at first, but they are very unreliable. I had them in my integra and was sending them in to get fixed more then I used them. The lights burnt out and sensors went bad like crazy. My friend has them in his Sti and went through the same troubles.
I'm pleased with my SPA dual-digital gauges, but, you're right, they aren't perfect. My Water / Oil temp gauge has been trouble: first there was a broken backlight and now the voltage warning symbol keeps blinking. I can't say if they're more accurate than other gauges or not, but they are definitely more precise.
Old Dec 7, 2006 | 05:07 PM
  #115
diablo2184's Avatar
damn im still stuck between the Defi and AEM gauges.....
hardest choice to make for the car....this and wheels.
Old Dec 7, 2006 | 06:39 PM
  #116
_EVOlved_'s Avatar
I chose AEM. AMAZING
Old Dec 7, 2006 | 08:26 PM
  #117
diablo2184's Avatar
pics? what gauges u running?
Old Dec 7, 2006 | 08:53 PM
  #118
spyderx's Avatar
Just ordered Greddy electronic boost guage. It has warning range starting at 24lbs, just fitting for IX. I'm hoping the electronic versions are more accurate than mechanicals. Anyways, there seems to be less chance of the vacum line being kinked.
I've tried many VDO, Autometer and other cheap ones. I'd rather spend a little more for a critical devise.
Then, I saw AEM Tru-boost. Hmmm, maybe later...
Old Dec 7, 2006 | 08:55 PM
  #119
spyderx's Avatar
he's probably talking about AEM's new electronic digital guages. I believe lancershop carries them.
Old Dec 28, 2006 | 07:05 AM
  #120
Yme's Avatar
Yme
Defi
