Those that store there evos for the winter...
Old Oct 30, 2006 | 12:23 PM
CarFanatic's Avatar
Do you use a battery tender, or just disconnect it?? also what all steps do you do to keep it stored? Do you start it up every so often or not worry about it?
Last year I started it up once a week or so, but I have the small buschur battery, and it always died on me.
Old Oct 30, 2006 | 12:28 PM
jrsimon27's Avatar
wash the whole car underneath it,engine compartment then wax it applay silicone to all the rubber and fill it up of fuel change engine oil and remove the battery from the car!
Old Oct 30, 2006 | 12:36 PM
money pit's Avatar
i use a battery tender. works great even with my mini battery. i start it at least once a week. actually just washed it and put it away last night. back to the 93 corolla, haha.
Old Oct 30, 2006 | 12:38 PM
midwestmonster's Avatar
Battery tender! The mini battery won't hold a charge if you don't. I picked one up for around $70 bucks. Just make sure the one you get is for a gel type battery, otherwise you risk damaging your mini.
sonicnofadz's Avatar
I just let it sit in the garage, and start it up (let it idle for 10-15 minutes) once a month.
Old Oct 30, 2006 | 12:49 PM
tsi90awd's Avatar
I change the oil, wash and wax, park it on a flat floor, put on a car cover, and run it for 15-20 minutes every month. I let it warm up completely, then rev it up until the cooling fan cycles on and off a few times.
I still have the stock, original battery. Usually, I keep it on a battery tender but it seems to be fine with just running it every once in a while. Compared to my old DSM, the Evo is remarkably kind to (stock) batteries.
Old Oct 30, 2006 | 12:55 PM
riceball777's Avatar
i would just start it up and run the car untill its fully warm every other week and you should be fine
Old Oct 30, 2006 | 01:11 PM
Brian's Avatar
Ditto, I may take it around the block.
That and I fill it up full of gasoline and put some stabilizer in it.
Old Oct 30, 2006 | 01:13 PM
mdacko's Avatar
make sure you put something under the tires, rubber or plastic or something like that. leaving them on the bare cement for prolonged periods tends to cause tires to rot and/or flat spot.
Old Oct 30, 2006 | 01:15 PM
mracing5625's Avatar
^^^ ill make sure ill do that...
Old Oct 30, 2006 | 01:39 PM
Dont Try To Run's Avatar
Excatly what i was going to say. You can put the car up on jackstands too... that wont hurt anything
Old Oct 30, 2006 | 01:47 PM
tsi90awd's Avatar
Oh yeah, when I run it every month, I also move it back and forth a bit. This is to get the oil in the transmission/transfer case/differentials to move around a bit. It might also help minimize corrosion on the flywheel and braking surfaces.
I also try to wind up with a different contact patch on the tires after each warm-up.
Old Oct 30, 2006 | 02:06 PM
modvp's Avatar
ditto...i wash, wax and treat the mouldings. I also add fuel stabilizer to the gas.
Old Oct 30, 2006 | 04:37 PM
CarFanatic's Avatar
ah great info!!
Where can I get a battery tender for the gel batteries?? where did you guys get yours?? I have some xtra carpet laying around would that work under the tires??
Why do you silicone the rubber?? If its sitting inside? This is one thing I haven't heard of before.
Old Oct 30, 2006 | 04:39 PM
NIevo's Avatar
I just put mine up on jack stands and bring the battery in the house.
