Fog lights on with Parking lamps!!!!
Old Nov 15, 2006 | 04:32 AM
mrbkkt1's Avatar
That's why I want to get a jdm front ecu, no need to fut around w/ making a gazillion relays. it's not that I don't enjoy the challenge, i just don't want to wire that much stuff.
damn computerized cars...
Old Nov 15, 2006 | 04:41 AM
Hot Wheelz's Avatar
I agree, no wonder why everone is not doing this. Just a shame. because imo it would look hot! All your responses are appreciated!!
Old Nov 15, 2006 | 07:19 AM
diablo2184's Avatar
So does the JDM ECU affect anything else or change anything else?
Old Nov 15, 2006 | 08:03 AM
SophieSleeps's Avatar
Originally Posted by mrbkkt1
negative, it doesn't work. I do know how to make it work though....
You will need a front ecu for a jdm evo. all the lights are ecu controlled from a seperate ecu in the engine bay, under the fuse box. seriously. i've tried everything to try and trick the computer, but will need a detailed wiring diagram to succeed.
There is a way around i'm sure. You don't need an entire ecu.
Run a seperate wire for the fog light switch. It's not that difficult.
If someone really wants to do it, just run a wire and a relay.
Old Nov 15, 2006 | 09:16 AM
hondafan's Avatar
is it any easier on the VIII? or is it just as complicated?
Old Nov 15, 2006 | 10:31 AM
GPTourer's Avatar
deleted
Old Nov 15, 2006 | 07:59 PM
mrbkkt1's Avatar
Of course I could run the entire foglights on a seperate power source, relays, etc. unfortunately, i'd have to get a new switch, since our foglight switch, is a different than the type that we would need. I would rather not rewire half the front end just for a foglight.
basically, if anyone has a diagram of the front ecu, i could probably make a fix.
Old Nov 15, 2006 | 08:08 PM
AZ EVO IX MR's Avatar
i did it on my nine, run your own wiring, oryou can hack in you wiring harness before you fuse box and run a wire from you parking light toyou fogs, either way you have to run your own wire. I did mine using a simple toggle.
do not do the method of running the wire in the relay box, this will blos the big black relay and cost you 165 dollars to fix.
total partscost me less than 20 bucks, look under my started threads and you will find the thread.
Old Nov 15, 2006 | 08:42 PM
It's not that advanced. It's 1 single relay. Same foglight swit
Old Nov 16, 2006 | 11:02 AM
diablo2184's Avatar
i have it from the dealer, if i can find a scanner, i will try and post it.
Old Nov 16, 2006 | 07:17 PM
Hot Wheelz's Avatar
Thanks Diablo - would love to make this work - If you cant scan send me a PM
I will contact the dealer myself. Then after I get it working I will post for us all to share
Old Nov 17, 2006 | 01:30 AM
trinydex's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=234531
help me out folks
i want the one wire mod. it's doable on an 05. i want it on an 04 and 03 others want it on 06s. DO IT.
Old Nov 17, 2006 | 01:39 AM
EVO8URV8's Avatar
Is it even possible just to rewire my fogs to make it work (or turned on) without turning on my headlights? (cause I replaced the stockers with some bright-azzed yellow fogs from PIAA)
Old Nov 17, 2006 | 03:45 PM
hondafan's Avatar
help me out folks
does that allow you to run the fogs without highs or lows being on? that's what i'm after.
Old Nov 17, 2006 | 05:17 PM
trinydex's Avatar
the only way to run them seperately is to have seperate actuation (switches).
