Fog lights on with Parking lamps!!!!
Subscribe
Dec 13, 2006 | 05:22 PM
  #46
thanks alot for sharing. appreciate the help.
Reply 0
Dec 14, 2006 | 02:57 AM
  #47
okay, just for the record, all you have to do to make the fogs come on is make a SPST switch to ground the relay for the foglight(of the 4 pins,drivers side rear). then you can turn on the foglight anytime you want. what I want to do, is make it so when I click on the stock foglight switch, it will turn on or off w/ parking just for the hell of it. i'm still hoping to find a wiring diagram for the front ecu, or maybe just a JDM or UKDM front ecu to play w/.
Reply 0
Dec 14, 2006 | 05:16 PM
  #48
Here is a very rough sketch of my wire harness. You'll need:
12 gauge wire
split loom
electrical tape
relay
relay socket
30A fuse
fuse holder
soldering iron
rosin core solder
spade connector to stick into parking light fuse in fuse box
Reply 0
Dec 14, 2006 | 05:31 PM
  #49
Ima definitely do this when someone comes up with the diy.!!
Reply 0
Subscribe
