Ultimate Racing Test Pipe, yes i did search
Originally Posted by boscoyo
If your car is an '03, then cap off the bung in the cat pipe and get a 19mm spark plug anti fouler(autozone) to screw into the bung where your sensor is now, and then screw in the sensor into the anti fouler, and tighten. Search anti fouler.
**edit: use this method before extending or cutting your wires.
Will it go on the test pipe itself or will it go on the catback exhaust because there is an o2 bung on there too, pretty close to where the catback meets the TP.
Thanks!
If the sensor will reach the test pipe, screw it in there. If not, use the fix that you have and put it into the cat back and cap off the test pipe with a plug. Either way you go, you will need to plug one of the bung holes.
Originally Posted by 3volut1on
What exactly do you mean when you say screw into the bung where your sensor is now? Do you mean on the catback itself? or on the Test pipe. I also have a mechanical o2 fix just in case. I am just a little confused as to where the sensor will go.
Thanks!
Thanks!
STREET CONCEPTS
10
Jan 24, 2007 08:18 AM
5k6
11
Jun 6, 2006 07:20 AM
