Quick Question
Old Nov 21, 2006 | 01:37 PM
jhanksevo's Avatar
Quick Question
hey guys I wanted to know if i didnt cap off the BCS when installing my MBC does it affect the adjusting of the MBC
Old Nov 21, 2006 | 01:40 PM
dan628's Avatar
why would you not want to cap it off? just do it the right way, you can get a whole package of caps at any auto parts store.
Old Nov 21, 2006 | 01:44 PM
jhanksevo's Avatar
No i didnt have a problem capping it off but i didnt have the caps during install and was told i didnt need them. My MBC seems to not even work right. i bought it used for an excellent price and I am real dissapointed
Old Nov 21, 2006 | 01:46 PM
dan628's Avatar
You should have waited to do the install until you had some caps. Its probably not working because the stock BCS is getting a false reading.
Old Nov 21, 2006 | 01:51 PM
jhanksevo's Avatar
Ok so that is what my problem maybe, because weather I turn the MBC down or up Im still spiking high like the MBC is not even affecting my boost
Old Nov 21, 2006 | 02:00 PM
snakedelong's Avatar
agreed
Old Nov 21, 2006 | 02:27 PM
jhanksevo's Avatar
thanks guys any other advice
Old Nov 21, 2006 | 02:32 PM
blackevoguy's Avatar
you dont have to cap off the stock boost controller. I have ams's kit and you only have to cap off the nipple on the outlet of the turbo and the nipple under the intake
hope this helps
Old Nov 21, 2006 | 02:51 PM
jhanksevo's Avatar
I actually have mine hooked up to the turbo nipple and the WGA nipple so u r saying the BCS can be left uncapped huh?
Old Nov 22, 2006 | 01:03 AM
yea u can leave it upcapped it will be fine ur boost controller might not be working right because of how u have it hooked up
Old Nov 22, 2006 | 06:24 AM
KartaRailed's Avatar
It needs to go, turbo>BC>Wastegate Actuator
There is no way that the stock BCS could be affecting your boost pressure because it has no way to control, mine is uncapped and runs fine, last night it was 35 degrees in jacksonville and I was hitting 21 psi, and not dropping off at all because the ambient are was keeping my turbo nice and cool, just stuck to 21 psi all the way to redline, and it felt good.
Tommy_Lee
Aug 4, 2010 01:34 PM
Motoxrider7
Dec 24, 2008 04:48 PM
mscorei
Sep 25, 2007 06:59 AM
silverevo05
19
Feb 16, 2006 01:49 AM
herbal77
Dec 20, 2004 04:48 PM
