boost ?
boost ?
i know its normal to drop boost but it always seems that people always are holding 19-20 to redline. My IX spikes 22-23 w/the mods in my signature but by redline it only holds about 17 or so. Is this normal or should i check for boost leaks or somethin
check for boost leak. Mine hits 21psi on 3rd pull and tapers down to 20psi without a tune.
You shouldnt have that much taper specially with ur MBC and a tune.i would check for a boost leak.Bfore i installed my hallman it would hit 20 and down to 15 psi.My MBC took care of ny taper.
i have the same problem with my IX. i was tuned for TBE w/ HFC, apexi intake, hallman mbc. my boost spikes 23psi then tapers to about 17-18psi by redline. i also had a boost leak test done right before the tune so i know i don't have a boost leak. so i was wondering what can be the problem. i know the IX's tend to taper more than the VIII's, but this seemed a little too much. anyone have any ideas what can be causing this?
Originally Posted by eponti
was it a dynoflash mail tune?Contact al at dynoflash he might have some ideas.He is very knowledgable.
From: City O Sin, MA...the not so sinish part though...
Originally Posted by PessimiStick
(You forgot an 'e')
and for the record i know how to spell breathe but because of a confusing forum joining process and disfunctional spam mail protection I ended up giving up with the typo name, what the hell do i care anyway.
Generally, if you are using an MBC and spiking at 22 you will taper to ~17 by redline (via true 3 bar sensor)....Most quote looking at a gauge which at speed is next to impossible....
There are a few that are controlling boost via the ECU and have been able to hold much more boost to redline
Originally Posted by LetItBreath
dont bother bumping until youve done a boost test...
you forgot to post something relevant...
Your explanation is fine though, I have _PessimiStick on a different forum for similar reasons.
Originally Posted by srt2evo9
i was askin of i should do a boost leak test or if its normal to taper that much before i do one
