View Poll Results: Waste of money?
Yes
75
27.99%
No
193
72.01%
Voters: 268. You may not vote on this poll
Mini Batteries... Are they Garbage? Waste of Money?
Old Mar 10, 2007 | 07:54 PM
  #76
Danny23's Avatar
I had a BR mini battery in my 03 8 and have one in my BR 350 IX,(comes with the BR350 package. My car sat for 3 days last week in below 0 temps and when i went to start it up it cranked up like it was summer out.
Old Mar 11, 2007 | 06:57 AM
  #77
MalibuJack's Avatar
It really depends on how much parasitic draw there is from accessories. Mine will go dead after a few days and I've isolated it to the aftermarket radio I'm running. I'm planning on putting the stocker back in since I had no problems for a long time before I put in the aftermarket radio.
Old Mar 11, 2007 | 10:52 AM
  #78
EzNateZ's Avatar
Originally Posted by talentsearch301
Install the stock battery in the trunk, will give you the same effect ... yes?
Battery is under warranty... so I will go that route
but the fear of going through this every (x) amount of months is a problem...
What will happen in the winter, when the car is parked?
Will probably have to go through this again...
These batteries die 25% faster in the cold... I'd consider a solar charger or a battery relocation kit.
Old Mar 12, 2007 | 09:18 PM
  #79
Tim893's Avatar
i have the 11lb one. it responds a little faster when u corner.
Old Jul 10, 2007 | 07:45 AM
  #80
talentsearch301's Avatar
Any pics of a solar charger?
I dont think a solar charger would work if you park in the garage for the winter...
Old Jul 10, 2007 | 10:16 AM
  #81
S1MPSONS's Avatar
15 lbs all-season Hawker Odyssey FTW. No problems with it here.
Old Jul 10, 2007 | 02:41 PM
  #82
sonicnofadz's Avatar
The mini batteries are an essential modification to save weight. It in itself might not do all that much but its a relatively inexpensive mod, especially if you just go out and buy a motorcycle battery and install it yourself. Having a mini battery, with lighter exhaust, lighter suspension, removed A/C, removed spare tire and jack, and other mods will start to add up, and before you know it you will be below the 3000lb curb weight.
Old Jul 12, 2007 | 12:22 PM
  #83
ajbreezay's Avatar
looking to upgrade soon good info!
-Aubrey
Old Aug 11, 2007 | 06:07 PM
  #84
badstainless's Avatar
Taylor + Optima Yellow Top FTW~
Old Aug 11, 2007 | 06:28 PM
  #85
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I had an Odyssey PC 680 and it lasted three + years with more than a few run downs, though I think it's dead now after sitting in the shop for three weeks.
Old Aug 11, 2007 | 06:59 PM
  #86
urslo4n8's Avatar
IMO a waste unless you use that reduction with other reductions to add to it such as jack and spare removal etc...or to make room for an UIP. id rather go a 10th or 2 slower and know i can change my flat if it happens and crank the engine over in the winter
Old Sep 16, 2007 | 01:19 PM
  #87
Kirbyryu's Avatar
Originally Posted by Joe's_EVO8
AKA trickle charger. It will keep your battery charged when not in use. It is like a battery charger but I think it only pushes in 1amp.
I have a charger that is capable of 6v or 12v pushes 1.5 amps and when I park my vehicles for long periods I just plug it up (mine came with a set of wires that bolt to terminals and have a quick connect plug) and always when I want to use the vehicle the battery is fully charged. Cost me 18 bucks from sears.
I am looking for a smaller than stock battery just not a mini battery. I know someone who has modified the battery tray for a mini battery but a mini just seems too small. Anyone got any suggestions that would be great.
Old Sep 16, 2007 | 03:17 PM
  #88
SkylineMyth's Avatar
How hard is it to vent the trunk, cause it's looking like I'm gonna have to relocate my battery because I do want a sound system but nothing extreme, just a single 12, and 2 amps, one for the sub and one for my speakers.
Old Sep 16, 2007 | 07:06 PM
  #89
4Trouble's Avatar
Would the 6lbs Braille battery sufficient for our cars?
There is no winter in Hong Kong and almost never goes below 50, it stays over 90F for 10 months.
I don't listen to radio or music in the car, I plan on removing the radio and the speakers.
However I do have OEM alarm system, they come with the car so if you don't want it, you have to remove it manually.
Old Sep 16, 2007 | 07:07 PM
  #90
4Trouble's Avatar
If you do it the ghetto way, its not too hard.
Just remove your wing and you have holes there to vent the battery
