View Poll Results: Waste of money?
Yes
75
27.99%
No
193
72.01%
Voters: 268. You may not vote on this poll
Mini Batteries... Are they Garbage? Waste of Money?
Old Dec 3, 2006 | 03:01 AM
pog0's Avatar
I think if you ever plan to race at an event, a kill switch is needed. I know for drag racing it is required. Not so sure auto x/road racing.
Old Dec 3, 2006 | 07:55 AM
GreddyEvo's Avatar
Originally Posted by Joe's_EVO8
I used an Odyessey PC-680 in the winter in Michigan for 2 years in a DSM with 0 problems. I think you need a new brand.
I agree with Joe. I have had the same battery in my VIII for about 2 years and I have no worries about winter start up. This will be the first winter for the battery since my VIII has been stored every winter before. The battery drops 20-22 lbs off the nose of the car, not to mention a high point on the car for that weight, so it helps lower the center of gravity a bit too.
Old Dec 3, 2006 | 08:16 AM
Jakeg97's Avatar
no
Old Dec 3, 2006 | 08:23 AM
PPI's Avatar
PPI
I have been using the Odyssey with my PPI battery kit for 1.5 years....no problems at all. I haven't even had to charge my battery as my car sits most of the winter! I couldn't be happier!
Old Dec 3, 2006 | 08:59 AM
aklucsarits's Avatar
I've had no issues using the Hawker/Genesis mini-batteries in my cars. They have worked fine, even in the dead of winter. I just sold one of mine that had been sitting around for about 2 years unused. Charged it up, and it's still going strong.
Old Dec 4, 2006 | 12:05 AM
Frenchy4g63's Avatar
Originally Posted by Rutt
Accessing the trunk area is easier than opening the hood. Pop the latch ond push the trunk up
I don't know how your car is set up, but I've never had a problem accessing my engine, or finding my battery in its stock location.
My hood opens just like my trunk, minus the additonal latch.
Old Dec 4, 2006 | 12:16 AM
x838nwy's Avatar
Well, I suppose it depends on what your intentions are.
If you want to make room to plumb your turbo/intake more efficiently or if the stock kit is getting in the way, then there's probably not a lot of alternatives and therefore it isn't a waste of money.
You probably loose a very small amount of weight and for how little it weighs, it's not going to much affect the weight dist. on the car (~10kg on a 1,500kg car) no matter where you move it.
Old Dec 4, 2006 | 02:19 AM
Rutt's Avatar
I think you confused yourself because I never mentioned anything about having problems finding the battery . I merely said it was easier to open the trunk since one less step is needed.
Old Dec 4, 2006 | 03:04 AM
Bro's Avatar
Bro
the odyssey pc-680 is widely used outside the EVO world too and has a great rep. I've used one with never a problem.
Old Dec 4, 2006 | 03:16 AM
HIPSI9's Avatar
im not so sure about that at all tracks though when i had my t/a the battery was in the back inside a bat box right next to my n2o bottle
Old Dec 4, 2006 | 03:00 PM
BiFfMaN's Avatar
Funny thing is that with BMW's (e36 and e46) its not consider "relocation" because its where the factory puts its....but honestly its not as "safe" as alot of the rule books says it has to be. Ie Box,vented, kill switch.... blah blah blah.
Installed Stock location W/o plastic cover ..nice vents and sealed box huh.
Now on the E46 i know they put a battery starter only disconnect where you would normaly find the battery under the hood. But no way to disco anything else in case of roll over besides getting into the trunk and removing the cables there.
but honestly the guy said "Relocate"..as in shifting weight back on our 60/40 cars
Old Dec 4, 2006 | 03:17 PM
Ultimate CC's Avatar
get a battery tender and it wouldn't have been an issue, i love mine...
Old Dec 4, 2006 | 03:21 PM
-=SPECTRE=-'s Avatar
One reason why some move the battery to the right rear is for extra weight over that wheel = extra traction for a RWD car. For an AWD car like an Evo it doesn't do much other than help the F/R weight distribution a little bit. But overall you're better off simply going with a mini battery if you can find one that is durable - and there are plenty of those.
Old Dec 4, 2006 | 03:29 PM
jroller's Avatar
when you run a battery from the rear (or even an alky kit) how are people running it from the trunk? Is it through the cabin area or between the outside skin of the body and inside?
Old Dec 4, 2006 | 03:35 PM
MalibuJack's Avatar
My opinions mini batteries are... they are garbage!
I have a few month old Genesis mini battery... I never had any problems until I disconected it to install my turbo kit...
turbo kit install is now complete... battery is deader than dead
had it tested, came back with a code
F03 internal open cell/ sulfated condition
Oh... I got this error while trying to charge a mini battery using a standard charger.. same exact error (must be a craftsman or sears charger)
Anyway, I put a battery tender on the battery which deep-cycled it and it has since recharged fully and has been recovered, has been working fine since then.. I ordered an odessey battery a few days before, and now I have a backup battery since the recovered battery has been fine.
