dent removal
Old Dec 8, 2006 | 09:31 AM
DentDude's Avatar
"$492.89"
seems about right for full repair (depends on b.shop and what they want to paint). i'v been with Dent Wizard (often imitated) since '01; try paintless dent removal first. the price usually will be below what your deductable is. it's true that anything on a bodyline is tougher to get out, but what may be left might be a little texture/orange peel on the bodyline. but NO dent will come out 100%; BEST case is about 90-95%.
as far as the scuff/scratch, some light compound and touch-up will probably work fine for what looks like (relatively) minor paint damage. but the touch-up can chip off during repair, so just i'd wait til after it's fixed..unless it's down to the metal (also easier to repair sans touch-up).
hope this helped and everything works out...anything else may be tough to answer with just pictures. good luck...
Old Dec 12, 2006 | 12:35 PM
Steve_P's Avatar
if you have paint damage, any decent body shop can fix that no problem; no reason to go to mitsu. They will repair the dings and then blend the Base Coat over the damaged area only. They will not BC the entire door- this way you won't see color mismatch. Then they will clear the entire door.
Old Dec 12, 2006 | 01:28 PM
skywestseth's Avatar
That sux...that is cool about the autopage though i am going to invest....
akemi27
Feb 11, 2011 08:44 AM
akemi27
Midwest Region
Jul 10, 2010 09:12 AM
akemi27
Aug 10, 2008 04:52 PM
akemi27
Midwest Region
13
Apr 10, 2008 12:07 PM
akemi27
For Sale - Cars For Sale
27
May 15, 2006 12:38 PM
