stewart warners, taking place of my mr gauges?
Old Dec 8, 2006 | 07:24 AM
fastassfourdoor's Avatar
Can i use the hookups from my mr gauges to hook up the stewart warner gauges.. In other words do i have to run all new wiring for the stewart warner gauges...thanks..
Old Dec 8, 2006 | 08:08 AM
oldscholevo's Avatar
i think you can tab into the power and reuse the vaccum hose for the boost.
Old Dec 8, 2006 | 08:16 AM
EVO8emUp's Avatar
I think the oil temp sending unit has different scaling However, they will give you a new drain plug with their sending unit.
If you do go thru with this, I need a factory drainplug / sending unit for the OEM MR oil temp gauge. I'll give ya $50 for it.
Old Dec 8, 2006 | 08:21 AM
sure thing man, I am gonna go threw with this, because i am going with a exhaust and mbc and flash, So im gonna need another boost gauge to go compensate for the increase in boost, and stewart warner are the best bang for your buck ive heard, instead of replacing the boost gauge only i can just do all of them because it will look a lot better imo. thanks for the replies guys..
Old Dec 8, 2006 | 10:40 AM
evo150's Avatar
i have had my stewart warner gauges for about a year now with no problems. i ordered them from 42draftdesigns along with the fittings for the oil pressure and oil temp to install the sending units in the blank plugs above the oil filter. here is a link to the lower gauge pod i have. https://www.evolutionm.net/forums/sh...ower+gauge+pod
tsidrift1
Aug 5, 2009 07:57 AM
shinnster
Oct 16, 2006 06:20 PM
Kodiak
Feb 19, 2006 01:17 PM
Kodiak
Mar 28, 2005 03:13 PM
mattfl
Oct 15, 2004 01:56 PM
