E-BAY parts that work well (evo only)
Old Jul 31, 2013 | 06:04 PM
  #556
seymour86's Avatar
Originally Posted by TeachersEvo
when you trim to fit, you lose the bead rolled ends and you will pop intercooler pipes off left and right.
Home made bead roller.
Old Sep 27, 2013 | 06:43 PM
  #557
TS Dork's Avatar
Anyone got a link to some good hood dampers that work well?
Old Sep 28, 2013 | 05:41 AM
  #558
JDMekB20's Avatar
x2
Old Sep 28, 2013 | 09:53 AM
  #559
596736's Avatar
https://www.evolutionm.net/forums/9990968-post365.html
Although it seems they raised the price they work very well and others in this this have had the same experience.
Obviously that ebay link ended but Here is a listing from the same seller. It seems they are black now.
http://r.ebay.com/DxVOWZ
Old May 28, 2014 | 09:32 AM
  #560
EvoG8r's Avatar
I'm missing my underbraces, so I have ordered a similar one to this from ebay. I can't see how this could be screwed up, but you never know.
Originally Posted by aggieEVO
Has anyone tried this?
03 05 Lancer EVO VIII evo8 4 Point Under Chasis Brace Bar Stainless Steel | eBay
I bought my car with no stock underbraces. This thing is cheaper than just buying a pair of stockers. Free shipping, too. I'd like to get a nice Cusco brace some day, but budget doesn't allow, yet.
Old Jun 6, 2014 | 10:09 AM
  #561
bluepeartype-s's Avatar
Registered User
ebay exhausts
SRS Exhaust..
I did a search on here but, not sure I got a definitive answer.. those that have it do you like it? hows it hold up? fitment good? and would you recommend? pics are good too!
Thanks!
B
Old Jun 8, 2014 | 05:58 PM
  #562
EVONOT's Avatar
Originally Posted by bluepeartype-s
SRS Exhaust..
Thanks!
B
I have one and its awesome. The fitment is on, but it could rub against your driveshaft when your rubber mounts get wet. Mine is a little custom. I deleted the cat and welded my test/midpipe together. But from the manufacture it will bolt up.
Old Jun 8, 2014 | 07:16 PM
  #563
WWJPD's Avatar
Originally Posted by artinist
when installing this you need to make sure the car is on a flat surface or else the chassis will flex and the holes will not line up. try to put the car on small 2x6 blocks of wood or put it on alignment jack so its flat and in fact you may have to try jacking up the car from different corners a bit to get the holes to line up. making the holes wider will weaken the structure a bit by letting the screws move under pressure.
How is fitment with a aftermarket dp with that $45 brace? Do they work with spacers?
Mitchimus
Aug 8, 2015 03:32 AM
av00va
Mar 12, 2014 03:00 PM
yenny
Aug 20, 2012 05:29 AM
cruzincarl
Feb 20, 2011 08:06 PM
Touge Factory
Evo 'For Sale' Exterior Styling
40
Sep 20, 2010 05:17 PM
