loose bolts (check yours)
just curious about your torque spec...is it 31 INCH/pounds or 31 FOOT/ pounds?
both are real numbers, but drastically different. (Yes there is such a thing as an inch/pound, for those of you who may be wondering...).
thanks, again, just curious, as I have never checked these and intend to , now that you mention it.
yes 31 inch
You aren't done yet. There's more than 6 bolts. Look under the cover.
These bolts need to be torqued every 12,000 miles. It should be listed as a maintenance item. After about three tightenings the gasket will leak anyway and then a new gasket is needed. Over tighten and you will cry at the price of a new cover.
thats some good info.. im gonna check out my car, i think every 5k or so everyone should look all around n make sure everything is tight, my wifes evo is starting to rattle below the car.. 13k miles thanks again..
ya IN pounds is a lot different then LB. I found this out the hard way when I was replacing the valve cover gasket on the miata.
31 in/lb is just a little bit tighter then hand tight.
mirage 4g93t
Apr 7, 2008 07:33 AM
OtownEvo
Sep 24, 2007 01:54 AM
all 6 are loose?
