ROBY MITSU SUCKS, wont fix my rust
so i jsut got a used rs evo8 like almost a month ago, car has 40k on it now and i took it in to get rust fixed iwas waxing my door jams and i pulled off the door stills and found rust starting from the metal on the door jam stills rubbing mitsu said that they can not warrenty that. little pissed off, time to call own and BBB. Ill get the car fully repainted hahahhaha
What's the rust protection policy on '05 models? I thought it was up to 70k miles or something like that with the factory warranty. Find out what it is and go back and tell him to suck it.
EDIT: I searched and found this eaily...
Basic Miles
60,000
Basic Months
60
Towing
Towing is available for any breakdown covered under either Basic or Powertrain Warranties.
Towing Miles
Unlimited
Towing Months
60
Extended Warranty
Triple Diamond Protection Plan offers many options to extend the service contract of the vehicle.
Rust
Outer body panel rust-through protection is 84 months/ 100,000 miles. Raider rust corrosion coverage is 84 months/60,000 miles.
Rust Miles
100,000
Rust Months
84
Original Battery
Free replacement during first 24 months/unlimited miles; 50% reimbursement for after the 24th month, but before the 37th month of service.
Original Battery Miles
Unlimited
Original Battery Months
24
Replacement Parts
Replacement parts are covered for 12 months/12,000 miles
Replacement Parts Miles
12,000
Replacement Parts Months
12
Powertrain
Powertrain Limited Warranty
Powertrain Miles
100,000
Powertrain Months
120
Tires
Covered by tire manufacturer.
Safety Restraint
Includes seatbelts and airbags.
Safety Restraint Miles
60,000
Safety Restraint Months
60
Transferability
Basic Warranty is fully transferable to subsequent owners at no charge for remainder of warranty. 120 month/100,000 miles Powertrain Warranty applies to original owner. Subsequent owners receive the balance of coverage remaining under the 60 month/60,000 mile New Vehicle Limited Warranty.
AC/Refrigerant
Refrigerant charge is covered for 12 months/12,000 miles.
AC/Refrigerant Miles
36,000
AC/Refrigerant Months
36
60,000
Basic Months
60
Towing
Towing Miles
Unlimited
Towing Months
60
Extended Warranty
Rust
Rust Miles
100,000
Rust Months
84
Original Battery
Unlimited
24
Replacement Parts
12,000
12
Powertrain
Powertrain Miles
100,000
Powertrain Months
120
Tires
Safety Restraint
60,000
60
Transferability
AC/Refrigerant
36,000
36
You'll want to focus on these 2 things...
and
A quick call to Mistubishi NA with your VIN handy should yield, at a minimum, some sort of soft copy of this policy...either with a PDF or a link on their website.
Rust
Rust Miles
100,000
Rust Miles
100,000
Transferability
Had the same problem with paint chipping and corresponding rust in the door area.
The local dealer did the paint repairs as a "one time good faith repair" after I made it clear that the repairs would be much more extensive/expensive if they let the rust continue. First time in my ownership of a Mitsu that they actually stood behind their product.
Good luck.
Good luck.
If all goes wrong, raise all hell in the showroom... It has worked for me numerous times with all different dealerships.. They will make you shut up. Go on a saturday afternoon when their showroom is really busy and scream your head off at the manager in front of everyone possible. He should kindly warm to yourself.
Right...umm...so when all else fails -- throw a tantrum? Immaturity for the win?!?
Nice.
Cabo
It's not covered under warranty anyways, if you read closely they say something like penetrated rust, or something similar. It basically means rust that has already went through the metal, or is going through the metal. The rust you have on their now is most likely just surface rust and can be taken off with some windex/simplegreen and elbow grease
GinNBoost
16
Mar 24, 2010 02:40 PM
jchangsta2six
Mar 29, 2006 01:09 PM
