3to4 gear grinding
Old Jan 11, 2007 | 09:40 PM
KIDBANGA10's Avatar
3to4 gear grinding
cant figure it out my 3 and 4 gear is grinding a little at high RPm any solution? Maybe because I need a new clutch.
Old Jan 11, 2007 | 10:05 PM
lightspeed1's Avatar
it's your synchros.. very common! It is covered under the 6/60k powertrain warranty
Old Jan 12, 2007 | 08:34 AM
19psi's Avatar
After looking @ his sig, I highly doubt his warranty is still valid.
Like the person above me said it's probably your synchros.
Try adjusting the clutch pedal (just a bit higher).
If that does not help, get ready to replace your sychro.
Good luck.
Old Jan 12, 2007 | 10:00 AM
jmartinez1170's Avatar
If you have a act clutch then there is your problem they tend to lock out on high rpm.
If not then it time to send your trans out to shep or tre.
Old Jan 12, 2007 | 10:10 AM
joshesh's Avatar
I have heard grinding 1 time, when I mis-shifted passing someone in 3rd shifting to 4th, bad sound - it hurt me too. What car is this, a IX or 8?
Old Jan 12, 2007 | 11:56 AM
slickevo18's Avatar
try changing your tranny fluid, if problem still persists, i'd look into a new synchro.
Old Jan 12, 2007 | 11:58 AM
davidevo's Avatar
i think is the clutch.
Old Jan 12, 2007 | 03:18 PM
evo@24psi's Avatar
I have the ACT and have no problems...................now that i have a Shep Tranny!!!
Old Jan 12, 2007 | 05:51 PM
frost318's Avatar
I had the same problem 3 to 4. It ended up being the synchros.
Old Jan 12, 2007 | 05:56 PM
prj.evo's Avatar
I had the same problem from 2nd to 3rd. I replaced all the shifter bushings with metal ones and changed the gear oil. Problem solved
Old Jan 13, 2007 | 02:57 AM
Tim893's Avatar
my does that too from 4th-5th on high rpm...
Old Jan 13, 2007 | 03:05 AM
4G63 T's Avatar
If you need repair and choose TRE...think twice before sending out...had bad experience.
Randal
20
Dec 7, 2012 12:54 PM
pb91
Jun 8, 2011 02:44 PM
SleepySamurai13
15
Apr 29, 2009 12:53 AM
Hcaruso4
Lancer Tranny/Drivetrain Tech
Jul 2, 2008 02:42 PM
