exhaust install
Old Jan 14, 2007 | 12:07 PM
chaz517's Avatar
exhaust install
i did a search but surprisingly cant seem to find a thread on how to remove the exhisting exhaust, turbo back, ne 1 know whre there is one? thanks
Old Jan 14, 2007 | 12:51 PM
19psi's Avatar
go to www.evomoto.com
There is a "how to" for a exhaust but..really it's very straight forward.
Old Jan 14, 2007 | 02:12 PM
nk1124's Avatar
all you have to do is get under the car and start unbolting stuff. It looks daunting, but the hardest thing about doing it all is really getting the bolts to come unstuck. Its relatively straightforward and it really is much easier if you have someone to help out.
Old Jan 14, 2007 | 02:21 PM
scenic's Avatar
Doing it on your own will take a while. If you can get someone to help you out, that will speed things up.
Old Jan 14, 2007 | 02:24 PM
XK120's Avatar
where in CT are you?
Old Jan 14, 2007 | 04:55 PM
chaz517's Avatar
allrite sounds good thanks 4 the help and websites, and i live in naugatuck
Old Jan 14, 2007 | 09:24 PM
evo150's Avatar
i did my install myself. make sure to support the exhaust with a jack as you uninstall the stock exhaust and reinstall the new exhaust. its best if you have 2 jacks
Old Jan 15, 2007 | 07:22 AM
DanJ's Avatar
pb-blaster and anti-seize is your friend.
Old Jan 15, 2007 | 07:52 AM
Neuspeed06's Avatar
Yeah its not really a hard install to do yourself......until you get to the Downpipe. I did the cat-back section just on jacks, but i had to get a lift for the downpipe.
Old Jan 15, 2007 | 07:54 AM
Juice33's Avatar
And don't take it off right after you have just been running the car for a while. It will be wicked hot! It takes about an hour or two to cool down.
Old Jan 15, 2007 | 07:57 AM
ak47po's Avatar
Old Jan 15, 2007 | 10:01 AM
brp's Avatar
brp
before you start make sure you get an O2 sensor removing tool, you should be able to get it at any auto parts store. i did mine by myself a few days ago and it was pretty easy to do, but my O2 sensor was stuck to the stock cat. at first i tryed to just use a regular open box wrench and it would not budge, bought the O2 sensor tool and anti seize, still nothing, it just started stripping it. so i got a hack saw and cut through the cat and used the O2 tool and a breaker bar and it came off. it took me longer to get the O2 sensor removed than it took to replace the whole rest of the exhaust in my case. but not everyone has this problem!
Old Jan 15, 2007 | 10:05 AM
staatz's Avatar
Unbolt the bolts that connect it. 2 on hte downpipe to housing, remove the hangers, pull it completely off. Remove the tie bars too.
Old Jan 15, 2007 | 01:23 PM
19.5PSI's Avatar
you can do this with one person but i highly recommend a buddy to help. you don't want to scrape up your new exhaust trying to move it into place. also heating the seized bolts with a torch helps in removal.
Old Jan 15, 2007 | 01:59 PM
mrfred's Avatar
Bummer. Mine came loose with a box-end wrench.
