Evo 8 exhaust on evo 9
Old Jan 16, 2007 | 06:26 PM
7oey's Avatar
So I know the tbe from a 8 won't fit on a 9. But what about from the exhaust from the downpipe back, meaning test pipe and catback? Will it also bolt up to the 9 downpipe. I'm asking 'cause I'm getting a really good deal on a evo 8 exhaust.
Old Jan 16, 2007 | 06:33 PM
ntwaddel's Avatar
yeah its the same. the only difference is the o2 bung is in the mid pipe instead of the cat. so you can just move your o2 sensor into the mid pipe
Old Jan 16, 2007 | 06:40 PM
RedV's Avatar
As far as I know, from the cat back, the Evo 8 and Evo 9 exhausts are the same. There are two differences from the cat forward that I know of.
1.) On the Evo 9 the O2 sensor is mounted on top of the cat itself, whereas in the 8 it is mounted after the cat more to the side on the exhaust pipe.
2.) The reason why people say that an Evo 8 exhaust won't neccessarily fit on a 9 is because of the ACD. A downpipe that was designed to fit an Evo without the active center differential, might not fit correctly on an Evo with the ACD.
To be clear, the 2003-2004 Evo VIII does not have the ACD. While the 2005 VIII and the 2006 IX have ACD.
Because of the extra room that the ACD takes up, some exhaust systems that were designed/tested on a 2003 or 2004 Evo, might not fit on a 2005 or 2006.
Notice I said "MIGHT". There are exhausts that say "for Evo 8", but will fit perfectly fine on a 2005 with ACD or 2006 IX with ACD. Some can also be "adapted" to fit.
Really, the only way to be sure is to have the exhaust bolted up and see if it hits the ACD. The second best way to tell is to search and find someone with the same exhaust and ask them how it fits on a car with the ACD.
Hope that helps.
Old Jan 16, 2007 | 06:44 PM
7oey's Avatar
Yeah I heard about how the acd may rub against the dowpipe. I was picking up a downpipe but I didn't want to buy an exhaust if it doesn't bolt on. Thanks guys.
Old Jan 16, 2007 | 06:51 PM
Warrtalon's Avatar
An VIII TBE will fit on a IX. Only some of the DPs out there won't fit due to the ACD, but many do fit.
Old Jan 17, 2007 | 10:25 AM
LateBrakeU2's Avatar
I have an 05 with BR 3" tbe,so that should fit a IX?
Old Jan 17, 2007 | 11:33 AM
Warrtalon's Avatar
05 and 06 would fit the same...
Old Feb 1, 2007 | 06:52 PM
7oey's Avatar
So I got my exhaust. It's a full tbe for an VIII. I know that the dp will touch the acd, but is that all? Or does it rub against it. The only think that I know about the dp is it's a new dp from ebay for an VIII. Should I just break down a buy a new dp or put it on?
Old Mar 7, 2019 | 11:21 PM
Camwarren3210's Avatar
Hope that helps.
So by any chance would i fit an evo 9 exhaust on a 2004 8mr? From what ive read the o2 sensor might not reach?
KamilEvolution
18
Jun 6, 2016 12:38 PM
detroit evo
Mar 8, 2016 06:29 AM
CrazyEights
Aug 1, 2010 11:45 AM
JRock
Aug 27, 2003 02:52 PM
1QWKEVO
34
Aug 11, 2003 07:40 AM
