What makes an Evo sound like this???
Old Jan 21, 2007 | 04:34 PM
recompile's Avatar
I'm sure most of you have seen this vid: http://videos.streetfire.net/video/1...3600391007.htm
I believe it's the latest WRC test car for Mistubishi.
I don't know enough about the rules of rally or about how rally engines are built to understand why the hell it sounds like this...
Can anyone shed some light on the behavior of this engine? The engine itself, the exhaust, the chirping bov (?) What's going on?!?!?! :-D
Old Jan 21, 2007 | 04:38 PM
hotrod2448's Avatar
Antilag, turbo choice, intake restrictor, cam choice all things that play a role in how the engine sounds.
Old Jan 21, 2007 | 04:57 PM
3SgteGuru's Avatar
your probably talking about hte Anti-lag. But there is alot more to it. The whole thing is like completely different.
Old Jan 21, 2007 | 05:01 PM
Psquared's Avatar
That's a cool *** short vid. clip!
Old Jan 21, 2007 | 05:06 PM
EvoRecordSetter's Avatar
id like some more info on antilag, what it is, how it works.
Old Jan 21, 2007 | 05:08 PM
hotrod2448's Avatar
I was going to say "I think it's Madonna".
recompile's Avatar
I found a post on EvoM that basically says:
"Bang-Bang" anti lag works by retarding the timing and dumping extra fuel at high TPS, and low boost pressure points of the map.
The retard of timing creates allot of extra EGT heat.
Send a ton of un-burnt fuel threw the engine with those high EGT's & you get an explosion in the exhaust manifold. The pressure from the explosion spools the turbo and wham 500ft/lbs at 3100rpm.
Just about any standalone ECU worth it's salt has an anti lag option.
"bang bang" Antilag is VERY HARD on turbine wheels. Plan on exploding a few a season.
Old Jan 21, 2007 | 05:10 PM
hotrod2448's Avatar
You are connected to the internet.
http://www.google.com/search?sourcei...antilag+system
Old Jan 21, 2007 | 05:12 PM
Hotshot940's Avatar
not to go off topic but i swear they use a lancer body with 4g63 and awd components and then they modify the body, the lines headlights and tailights look so 02-03 lancerish.
Old Jan 21, 2007 | 05:26 PM
hotrod2448's Avatar
That's because they do.
Old Jan 21, 2007 | 09:18 PM
koolguy660's Avatar
yea thats sick what they did to the appereance and it sounds nice... i actually like it
Old Jan 22, 2007 | 09:29 AM
stikillller's Avatar
where are the roads like that here in the US! nice evo
Old Jan 22, 2007 | 10:03 AM
EVO8emUp's Avatar
They call it the "Bang, Bang", or anti-lag... If you drive your car on the street all the time, you don't want it. It's not uncommon to to snap impeller shafts, not to mention it dramatically reduces turbocharger life.
oops, I see this has already been covered ^^^^^^^^
Old Jan 22, 2007 | 10:26 AM
Rice King's Avatar
pretty sure its the same anti-lag that sebulba uses
http://www.youtube.com/watch?v=9jMIQ...elated&search=
Old Jan 22, 2007 | 01:45 PM
evoixbri's Avatar
can be many things.
