Boost creeping...a lot
Old Jan 26, 2007 | 07:57 AM
  #31
UpstateEVOVIII's Avatar
working on adjusting the wga now...soaking the nut as i can't turn it currently...little bugger is putting up a real fight. will post results as soon as i find out who the offender was
Old Jan 26, 2007 | 08:28 AM
  #32
kapolani's Avatar
How goes it?
Old Jan 26, 2007 | 08:31 AM
  #33
still cooling off fromt eh drive to the garage and soaking the nut as it's on there awfully tight. hopefully in the next hour or 2 i'll have more information
Old Jan 26, 2007 | 08:44 AM
  #34
Not the wga...ugh. Has to be the flapper hitting on the inside of the o2 housing time to rip it out
Old Jan 26, 2007 | 09:43 AM
  #35
EVIL_EVO_VIII's Avatar
Trust me, you have to turn the buckle that attaches to the hotside and turn it.. It will work
  #36
TTP Engineering's Avatar
Its not the O2 housing.
I could bet money that the Forge UNOS is not hooked up correctly OR its a combination of using the HARD spring in the UNOS.
Old Jan 26, 2007 | 09:49 AM
  #37
Currently the MBC is not even hooked up. The wastegate is hooked directly to the turbo right now for testing to try to solve the problem. The MBC is completely out of the equasion as I stated previously.
Tested the WGA and the arm travels approx. 1/2". Not sure if that's enough, don't know enough about our WG. The arm has been readjusted and there is minimum preload on it currently. WG moves freely when WGA arm is removed.
Old Jan 26, 2007 | 10:31 AM
  #38
Tried that..had it as loose as it can go without it rattling. No go.
Old Jan 26, 2007 | 10:46 AM
  #39
I dont know then.. Maybe something isnt hooked up right
Old Jan 26, 2007 | 10:59 AM
  #40
Replacing all of the lines in the boost system currently to ensure there were no leaks. Everything has been checked and double checked to be hooked up correctly. Hoping for a miracle here.
Old Jan 26, 2007 | 11:30 AM
  #41
Warrtalon's Avatar
The stock boost system only works properly with the stock boost lines. What did you mean by hooking the wastegate directly to the turbo? I thought when you removed the MBC, you re-hooked up the stock boost system going to the BCS and such (this requires the OEM hoses with restrictor pills).
Old Jan 26, 2007 | 11:40 AM
  #42
we hooked the turbo directly to the wastegate so the car would only build as much boost as set by the wastegate to eliminate outside factors (bcs, mbc, ect). what do you mean it only works properly with stock boost lines?
Old Jan 26, 2007 | 11:46 AM
  #43
Warrtalon's Avatar
I'm only referring to when the stock boost system is hooked up. I thought that's what you meant you did when you said you removed the MBC back on page 1. I would have done that as a test, too, not just connect the turbo to wastegate.
Old Jan 26, 2007 | 11:59 AM
  #44
We will try that next. May have found a section where a hose attaches to the nipple where the hose is swelling. Hoping to have this resolved TODAY
Old Jan 26, 2007 | 01:14 PM
  #45
replaced all lines, still no go...ugh
