Good source for Evolution VIII timing belt?
Old Jan 30, 2007 | 07:49 PM
heavens turbo's Avatar
the only reason the dealers tell you it's 100000 miles before belt replacement is because consumer reports judges a car on how much it costs to maintain a car up to 100000 miles. you can try to stretch 100k out of a timing belt, but i think it's very safe to replace it at 60k. as a mechanic, i've seen people try to go 100k before t-belt, waterpump and they just dont make it. waterpump fails and coolant goes onto belt, shredding the belt and even jumping time. i would do the whole shebang. the dealer will say you dont have to but it's even more money if you blow your engine....... (not saying they would want your car to blow up, but better safe than sorry.)
Old Jan 30, 2007 | 08:19 PM
evolv x's Avatar
60K service
How much did the 60 K service cost?
By a dealer or an independent?
Any recommendations for a quality shop in Ventura county, CA.
Thanks
Old Jan 30, 2007 | 08:29 PM
BUCKNAKED's Avatar
Originally Posted by gsrboi80
Like I said cheap insurance at 120 i'll do them agian. Balance belt fails your F)&ked, water pump fails you better hope it doesnt lock up the sprocket and shread the timing belt or your fu(&ed, hydrolic tensioner fails you Fuc)(d oh and it does happen trust me Ive seen it on a friends integra and on an 00 Eclipse GT both time no more motor. Since your in there change it.
I see you have a lot of trust in your engine. I think Mitsubishi has gone with the 4G63 for so many years for a reason. Its a toned down version on their rally cars!!! That engine is a tank. But hey its not my money that being thrown away! A Evo Mechanic sole job is to work on...Evo's, on a daily basis. I would follow his advise any day. That is not to say its wrong to replace all those parts, I'm just amazed how people freak out about the timing belt change. Yes, the belts are vital that they are changed. But they would have listed the
water pump etc. to be changed if it was designed to fail at 60k. For every car that has tensioner, water pump etc. fail, their is the 99% who have no problems. Once somebody posts that their such and such failed, the ripple effect is amazing, like everybody should go out and get it replaced the next day, without looking at the big picture. That is what TSB's are for: Obvious known mecanical failures that need revising or replacing.
Who is to say it has to be done at 60k?
Its just a known mileage where the belt is at its lowest limits or beginning of deterioration. Some go longer some change it earlier. But hey if you distrust your engine and feel like you're gambeling with an engine meltdown or are planning to run the car into the ground and keeping it for a long time then go for it replace everything. Just my .02!
Old Jan 31, 2007 | 08:12 AM
TTP Engineering's Avatar
Timing belts can break or wear, period. Combine that with running with no tbelt cover on the gears and you wear it out faster from dirt, debris and oil.
The Gates timing belts are the best available and is what we run on our own car. They are not TOO RIGID or tight. The tightness is set by the tensioner and autotensioner and if its too tight, it is due to installer error as they overtightened the tensioner.
Old Jan 31, 2007 | 08:21 AM
Smike's Avatar
For 03-05 Evos:
MR984375 - TIMING BELT ADJUSTER
MD326059 - TIMING BELT
MR984778 - BALANCER BELT
MD352473 - BALANCE TENSIONER
It was about $230 out the door for all those parts. A fellow mievo.net member and I did this at his friends garage.
The dealers I talked to wanted about $650 for the install w/parts.
shupadupa's Avatar
So what was that dealer cost installed? I am currently at 61K on my 03 and thinking about paying since i get iffy on this repair, based on the impact if done wrong.
Old Jan 31, 2007 | 03:49 PM
BUCKNAKED's Avatar
Originally Posted by SmikeEvo
For 03-05 Evos:
Ditto. And I had the dealer install everything except tensioner, and paid close to $700. But that also included T/B cleaning, Leak down test, Idle base and set timing(Found out afterwords is a waste of money after talking to the mechanic he said it was really not necessary) and complete inspection which usually is free.
Old Jan 31, 2007 | 03:52 PM
BUCKNAKED's Avatar
Great plug for your $200 belt vs. OEM $75 Just as good!
Old Feb 3, 2007 | 01:52 PM
Eva01's Avatar
I will just go ahead with the manual's recommendations. My mechanic said it is fine to follow and do the balancer belt and water pump at 120K. He says the b. belt most of the time does not go throug the same stress as the timing belt while being made a bit stronger (thicker). I can get the OEM belt from the dealer for $40 inc. tax.
Eva01
Old Feb 3, 2007 | 02:32 PM
gsrboi80's Avatar
Buck its a known thing man do the timing belt do the water pump and tensioners. Not just in the Evo but in all cars. Dont do it if you want but dont knock the people who do. Like I said its cheap insurance. I do have faith in my engine Preventative maintenence FTW. Your just saying all this cause your worried now that you didnt change it
Of course you beloved mitsu dealer will tell you not to use a stonger belt. Duh. Installation error on the ones he had at the shop that were frayed.
To each their own. I know Im good are you
Old Feb 3, 2007 | 02:37 PM
gsrboi80's Avatar
Like I said I have seen failures in these parts as well (waterpumps, tensioners and belts before 100k) Screw what your dealer told you I know what Ive seen in 10 years wrenching on cars. I make sure it's not happening to my ish. The extra couple 100 is way worth my piece of mind.
Like I said Buck your just trying to justify your not changing the obvious. Ive got my fingers crossed for you buddy
Old Feb 3, 2007 | 08:01 PM
BUCKNAKED's Avatar
I was never knocking anyone for replacing their parts. Buy a whole new car at 60k I don't care .
I was not aware your being part of Mitsubishi's engine development team for all these years and you're an automatic wealth of knowledge about engine part fatigue and your "Insurance." Your comments about "crossing your fingers for me" and "I only regret changing mine," Is a class act from a 10 year veteran Good job for scaring a few more Evo owners to schedule their dealers first appointment to change all the parts that, not only my dealer, but the origional poster's dealer told him that is unnecessary Maybe you saw so many timing belt and tensioners fail is because you installed them or, never took it to the dealer, but I forgot you probably already know my dealers mechanic since you know he incorrectly, lol, installed (more than one) the SS kevlar gold plated, diamond encrusted, etc. belts. Keep
Old Feb 4, 2007 | 06:37 AM
gsrboi80's Avatar
I didnt install the ones Ive seen fail jackass they were factory. Keep taking your car to the dealer to get worked on. For what I paid for my insurance you paid in labor smart guy. You dont even work on your own ish so you cannot relate any real life expierience. Your a tool.
Im not trying to scare anyone just stating the obvious. The tensioner is 100 bucks (well 200 for you since you would have the dealer install it). People are crazy not to change it
Old Feb 4, 2007 | 11:03 AM
BUCKNAKED's Avatar
I am not the one who spent any extra money, you did! Hello, you're the one advocating getting a shopping cart when you to the dealer/autoparts store. So talk to me when you reach 80k. And you will have still spent more, but you're insured and I will have extra money for more mods (P.S. stop spying on me or if your gonna look in my garage thats typically where I work on my Evo. You won't see me doing the timing belt because its the only thing thats been done at the dealer)
Old Feb 4, 2007 | 01:09 PM
shupadupa's Avatar
Jesus, so much love in this thread. Good reading though, and thanks to the poster above who qouted the dealer installed prices.
