Evo VIII vs Evo IX with dyno graphs!
Old Mar 2, 2007 | 04:16 PM
  #31
freddiet's Avatar
I would like to this also, I am sure warr will be on soon he seems to know everything
Old Mar 2, 2007 | 04:30 PM
  #32
gsrboi80's Avatar
Its everything on the IX motor that adds to the amount of power it makes over the VIII.
-Compressor Housiing
-Mivec
-Cooling
-More boost/Same gas
He will make more power than you. Youll need to add cams to be close. An upgraded turbo and you'll pull ahead
Old Mar 2, 2007 | 04:40 PM
  #33
EVO8904's Avatar
Originally Posted by tvbf1
Are you sure it's not because of the Turbo? I know that both the VIII and IX has a TD05-16G but the IX has a bigger compressor housing.
Not trying to start an argument, but since you said that the IX runs on a more aggresive cams, do you happen to know what's the spec on both the VIII and IX cams?
Do a search, I saw the specs for the stock EVO cams on here some where. The IX does have more aggressive cams, bigger compresser housing and it runs a higher boost. Those are the reason it will make more power.
Old Mar 2, 2007 | 05:49 PM
  #34
Steiner's Avatar
Originally Posted by space
what about the VIII MR, ive heard a few people say this has it over the IX easily?
In the USDM all Evos of the same model year make the same power. An '05 VIII MR makes the sme power as the '05 VIII RS and '05 VIII GSR. Same turbo. Same engine. Same tune. Does Australia get a more powerfull powerplant in their MR?
Old Mar 2, 2007 | 07:39 PM
  #35
evobeatsti's Avatar
I got my results today. at 21 psi on 91 pump gas i made 300 lb ft of torque and 305.1 whp, when i did a 50/50 mix with 104 octane (equaling about 98 octane) i made 325 whp and 310 ft lbs on 21 psi by just advancing timing. i am guessing my friends evo ix will make my 99 octane number on pump. i will post graphs when i get a scanner later tonight.
Old Mar 2, 2007 | 07:55 PM
  #36
mcwop23's Avatar
the biggest difference between the VIII and the IX is the turbo. VIII guys are upgrading to IX turbos and getting like 15-20 WHP gains
Old Mar 2, 2007 | 08:41 PM
  #37
supersupra's Avatar
Please post the graph!!!+1
Old Mar 2, 2007 | 08:44 PM
  #38
smarsenal's Avatar
Pretty cool comparison project, but if you want to see the real difference between the IX and the VIII, shouldn't we be using stock vs stock, or at least the same after-market mods on each. This would show the true difference between the 2.
Old Mar 2, 2007 | 10:52 PM
  #39
evobeatsti's Avatar
here is my whp graph bottom line is base run, middle is 91 octane pump at 21 psi and top is 91 and 104 mix (about 98 octane) at 21 psi.
Old Mar 2, 2007 | 10:53 PM
  #40
evobeatsti's Avatar
here is my torque graph kinda hard to tell whats going on but just divide the numbers by the ratio of 4.532 and you will get my torque numbers.
Old Mar 2, 2007 | 10:55 PM
  #41
saetern's Avatar
nice numbers, can't wait to c the comparison
Old Mar 2, 2007 | 10:58 PM
  #42
evobeatsti's Avatar
ya i was really happy with the numbers the evo ix tune might be delayed for a few weeks as the tuner is going out of town but i will have those numbers up as soon as i get them.
Old Mar 2, 2007 | 11:58 PM
  #43
SophieSleeps's Avatar
i don't have my IX dyno charts but they are consideratly different than yours.
Power is smooth as a butt and doesn't drop...just continues until redline.
306hp at around 7000rpm.
I had peak torque about 3700rpm and it declined at a very gradual slope. Not nearly as dramatic as yours.
Old Mar 3, 2007 | 12:51 AM
  #44
alexlewand's Avatar
in two weeks I will dyno my new IX. And same day after it will receive JIC Magic TBE with Racing O2 housing. Cosworth cams, fuel pump, AVCR, HKS racing sucktion, new injectors. And will see what it will dyno then I am just waiting to brake it in first.
So I will post some dyno pics.
Old Mar 3, 2007 | 01:19 AM
  #45
Nad1370's Avatar
98 oct pull.
325whp peak@5200 rpms and nose dives to around 260whp by 6800 rpms.
Not very familiar with Dynapack, but that's a 65whp drop in less than a 2k rpm range.
What is your boost reading at 7000rpm's?
Plan on getting cams?
