getting off the gas it feels like compressor surge help
Old Mar 9, 2007 | 02:09 PM
STOMPER!'s Avatar
Question getting off the gas it feels like compressor surge help
when im getting off the gas the car surges. if you are coming off boost. the hose coming off the bov to intake looks a little kinked.would that cause it
Old Mar 9, 2007 | 02:17 PM
coffeeslug's Avatar
A kinked hose would seem to indicate that you have an aftermarket valve using the stock hose. The kink itself is probably not the problem. What valve are you using?
Warrtalon's Avatar
If you come off the gas while under partial boost and let off the gas slowly, it will cause flutter and surging.
Old Mar 9, 2007 | 02:24 PM
STOMPER!'s Avatar
that is what is happening. The bov is FP. there is nothing you can do to stop the surging. if feels like compressor surge. Is that what it is?
Old Mar 9, 2007 | 02:28 PM
Warrtalon's Avatar
Yes, it is. That's what happens with a strong BOV on a car that boosts this much. You just have to learn how to avoid it by doing a full lift of your foot, else you just deal with the surging.
What is FP?
Old Mar 9, 2007 | 02:30 PM
boost_junky2000's Avatar
What are the long term affects of compressor surge? Decrease in turbo life?
Old Mar 9, 2007 | 02:47 PM
bluebyu36's Avatar
i just got the forge rs and i't took away the problem. when i adjust it loose.
Old Mar 9, 2007 | 02:51 PM
Danny23's Avatar
compressor surge and bov flutter are completely different things. Com surge is when the blades in the turbo stall or slow down for whatever reason and bov flutter is the piston in the valve obviousely fluttering up and down. To answer your question com surge will after time damage the turbo.
Old Mar 9, 2007 | 05:25 PM
Jakeg97's Avatar
make sure your bov is not installed backwards as that would cause what your feeling.
if you havent touched your bov , then nevermind
PINK LANCER
Lancer Engine Tech
Nov 9, 2013 08:11 PM
Mitsu.kid.02
Lancer Aftermarket Forced Induction Tech
Dec 17, 2010 09:41 AM
l2r99gst
Sep 17, 2009 07:12 AM
bbyevo8u
23
Jun 16, 2007 02:21 PM
EvoRs
Jul 27, 2004 11:40 AM
