Why is the resale value of the XEDE so terrible?
Old Jun 20, 2007 | 05:51 PM
  #61
smokedmustang's Avatar
Originally Posted by Spooldyou
In a sentance....
The same thing happend to the UTEC, AFC, and soon to be any other major piggy back ECU, ECUFlash has Put them to shame as far as it expandability, and future support. I wouldnt see why you WOULDN'T go with a Reflash. Im running a 35r 1000cc Injectors, and TIAL 50mm ( VTA BOV) with Awesome luck. You just have to learn how to use it the correct way. I'll Never Run AEM / Standalone because i bleive in the right hands the stocker is way more capable than people make it out to be. Just my 2 cents.
THOSE ARE AWESOME 2 CENTS!!! I agree! That is where I will be shortly. Thanks for the words of encouragement!
Old Jun 20, 2007 | 06:36 PM
  #62
A418t81's Avatar
The Xede has its place for now. Knock attenuation helps, so does the NTLS and launch control features. Finally, it makes a great safeguard solution if you have SMART and want to run meth.
Old Jun 21, 2007 | 12:35 AM
  #63
Erik@MIL.SPEC's Avatar
Here in Southern California the XEDE has a reputation as being buggy and unreliable. I can't comment on that hearsay, but I will say that personally, my unit took a dump on me. Now, Vishnu was very helpful and replaced my unit, however once bitten...
I may use the conditionals like lean-run protect along with a flash. Haven't made up my mind yet...
Old Jun 21, 2007 | 11:15 AM
  #64
LT1runner's Avatar
I dumped mine and went with MAFT pro. I'm on meth with a 30r, 280s and the car runs great. Idle is rock solid. Speed den. is awesome.
Old Jun 21, 2007 | 01:01 PM
  #65
I considered the maft pro. Is it an easy thing to setup/use? I hear all you have to do is "Type in" the AFR you want to see at WOT, and it will hit that every time. Is that true?
Old Jun 21, 2007 | 01:11 PM
  #66
LT1runner's Avatar
Yes it is. It's awesome, and it reminds me of Xede smart. Also I hear they have an update to control timming as well. I've not read this for myself yet, but it's really good so far, and it'll keep the AFR at 30psi. I'm running a 2.3 w/30r, 280s, and it runs great at idle, on the street, highway, drag strip, and autocross.
I also went through emissions testing with it with no problem No MAF codes thrown at all. I'm running it in speed density mode, so no MAF at all. VTA tial, and Meth.
Old Jun 21, 2007 | 01:59 PM
  #67
It is definetly Something to consider!! Thanks for sharing. So there are benifits of using this and your stock/flashed ECU? I was told you CAN'T use a piggyback or a standalone, or an SAFC when using this part, and that it is user friendly and really simple to hook up/use.
Smogrunner
Jun 26, 2017 03:54 PM
hackish
28
Mar 7, 2017 09:32 PM
13-0
154
Aug 16, 2015 12:57 AM
nj1266
17
Jul 22, 2006 10:38 AM
shiv@vishnu
58
Aug 11, 2005 05:40 AM
