Lowering the launch control
Old Mar 15, 2007 | 06:28 PM
Sschmuve1's Avatar
My car has just recently been flashed, and the rev limit was raised to 6000. Now I could never bring myself to launch it at 5k, for fear of damage. What if the 2 step was lowered to 3800? And you sat building boost at near peak torque rpm. Wouldn't this make for a good and "Safe" launch?
Old Mar 15, 2007 | 06:32 PM
AF-Evo8's Avatar
its not high enough you would bog off the line at 3800rpms.
Old Mar 15, 2007 | 06:57 PM
ries's Avatar
There's really no such thing as a "safe" launch, its more of practice makes perfect
Plus, your not going to build boost quickly if its set at 3800...you will also most likely have to slip the clutch more to get a good launch like you would normally.
Mine is set at 5650 and works great...just remember if you wanna play you gotta be willing to pay...
Old Mar 15, 2007 | 06:58 PM
Ultimate CC's Avatar
if you launch properly its really not that harsh on the car, the clutch yes but not the entire car...
Old Mar 15, 2007 | 07:00 PM
bigric09's Avatar
you sure yours is there ? did you change it ? AMS set mine to 6125
Old Mar 15, 2007 | 07:25 PM
evrblazin's Avatar
yea take it from you who just blew his tranny a few months ago
Old Mar 15, 2007 | 07:26 PM
FastAzzEvo's Avatar
i set mine at 3K just to see what it would do? Basically, i just got my tactrix cable and was just playing around.
I got a check engine light for doing that. DOn't remember what the code was, but the car didn't like it. I think the ecu saw that drastic change 6K to 3K and flipped.
ANyhow. I have mine set at 6K and use it often at the track.
How much boost do you guys build with 2 steps near 6K?
I have zt2 and log boost, and I only build 5-6psi with it at 5000K
And about 7-8 at 6K, i'm trying to figure out if it shoudl be higher or not? Or maybe I have a leak somewhere.
Old Mar 16, 2007 | 07:25 AM
bigric09's Avatar
im guessing leak... im pretty sure i build at least 10 to 12. Also how much you build is determined by how much your throttle is open. If you barely touch the gas, you dont build much at all.
Old Mar 16, 2007 | 09:12 AM
red evo8's Avatar
practice my friend practice
Old Mar 16, 2007 | 09:43 AM
joeMama's Avatar
not gonna be much of a launch @ 3800!!
Old Mar 16, 2007 | 10:05 AM
occultworks's Avatar
I set mine to 4500 and it works okay. Builds 5psi.
Old Mar 16, 2007 | 08:22 PM
thaigleshmk's Avatar
mine was raised to 5,800 rpm
Old Mar 16, 2007 | 08:24 PM
4TUN8's Avatar
Mine is 6500..../shrug bigger turbo needs a bit of coaxing off the line =p
Old Mar 16, 2007 | 09:31 PM
CRX2EVO's Avatar
I just had mine flashed to 6,000. Used it for the first time today and bunt the clutch nicely lol.
I was told to expect about 12lbs at 6,000.
Old Mar 16, 2007 | 10:06 PM
ries's Avatar
Chris asked me what I wanted it at and I told him between 5600 and 5700...so he set it right in the middle. I build 8-10 psi pretty quickly but might raise it a little for the track
