new TBE!
Old Mar 29, 2007 | 10:36 PM
chaotichoax's Avatar
you should search first...I guess everyone is in a good mood answering your question
9,000 people have had this issue and you obviously were too lazy to check first
Old Mar 29, 2007 | 10:39 PM
bhamEVOguy's Avatar
Originally Posted by sixfatbabies
your o2 sensor is reading way to much exhaust flow due to the restriction of your catalytic converter being cut out the picture. search the how-to section for a spark plug non-fouler to plug your o2 sensor in. It works.
yep best way to do it. easy n cheap. worked 4 me
Old Mar 30, 2007 | 05:41 AM
urslo4n8's Avatar
I recently installed a 3" TB exhaust i used the o2 bunghole in the cat back rather than in the cat delete pipe...............the cell light came on after 50 miles......so i did the 'ol spark plug anti-fouler and 60 miles later..........NO CELL.......that cool trick seems to work well.
Old Mar 30, 2007 | 11:42 AM
jcdevo67's Avatar
yeah the spark plug non fouler is def the way to go to keep the cel off
Old Mar 30, 2007 | 12:11 PM
ddddddana's Avatar
Old Apr 1, 2007 | 07:18 PM
TheTumblerIX's Avatar
+1 on the non fouler. However, you're going to need a tune as well. Under normal driving, my car was fine with TBE and no tune, but when I would drive it hard, I would get a pretty harsh boost cut at about 6k. Like everyone has stated before, this is a common problem.
Old Apr 1, 2007 | 07:39 PM
Jeff_Jeske's Avatar
Post some pics of your exhaust!
Old Apr 1, 2007 | 07:52 PM
AWDTurbo4's Avatar
old topic but oh well
2 spark plug anti-foulers (18mm). It is made by the HELP! brand part#42002 or 42009
Old Apr 2, 2007 | 09:29 AM
IX stealth MR's Avatar
If the wire to the O2 sensor in the cat were cut, could it still be wired not to throw a code?
Jschlo4
Apr 12, 2011 10:13 AM
Silversx
13
May 7, 2009 11:21 AM
bouncintiga
Feb 19, 2009 07:16 AM
Mr.IX
Mar 13, 2007 05:57 PM
GgreyEVOIX
Apr 13, 2006 06:56 AM
