new TBE!
Old Mar 29, 2007 | 04:29 AM
AAEVO9's Avatar
new TBE!
hi, last night i installed my TBE by "TurboXS" with a cat-delete. this morning im driving by and my "service engine soon" light comes on. should i be worried? why does this happen? i can imaginge the "O2" sensors are not feeling all this air-flow!
seriously should i be worried????? thanks.
Old Mar 29, 2007 | 04:31 AM
DanJ's Avatar
get the CEL checked.
Dead-Man Inc's Avatar
it happened to me too after installing a TBE
all i did was disconnected the battery for 5 min, then reconnected, and the problem solved
Old Mar 29, 2007 | 04:33 AM
AAEVO9's Avatar
did the problem go away 4eva?
yes it did, only sometimes it appears for few minutes and disappears by it self
Old Mar 29, 2007 | 04:34 AM
AAEVO9's Avatar
yes it did
fo'sho' thanx!
Import Junky's Avatar
good info to know.
Old Mar 29, 2007 | 04:35 AM
AAEVO9's Avatar
yeap those O2 sensors can be a biatch
Old Mar 29, 2007 | 05:33 AM
Curt941's Avatar
Umm, search for "mechanical fix" in the how to forum, you'll find a way to fix the light.
what is happening now that you don't have a catalytic converter, is a bunch of junk that didn't used to get all the way to the second O2 sensor is now getting there and your ECU thinks the catalytic convertor has gone bad.
Old Mar 29, 2007 | 09:35 AM
19.5PSI's Avatar
i have the same exhaust but witha hi-flow cat. got the CEL also and did the disconnecting of the battery. it worked for about a day and then it came back on. still on as we speak.
Old Mar 29, 2007 | 09:41 AM
merkzu's Avatar
do the spark plug non-fouler fix or wire in an O2 Simulator, don't need an expensive O2 sim, I bought this one off ebay for $20, works perfect
http://cgi.ebay.com/ebaymotors/Dual-...QQcmdZViewItem
If you want to totally remove the rear O2 sensor you need to get the additional resistor for $5 to simulate the heater
Old Mar 29, 2007 | 11:18 AM
nutsack's Avatar
speedelement sells a mechanical fix for $13 shipped if you don't want to mess with drilling out spark plug anti foulers. it works great.
Old Mar 29, 2007 | 02:30 PM
staygold's Avatar
your cars fine just use the mechanical fix or just try the battery solution first.
Old Mar 29, 2007 | 02:36 PM
sixfatbabies's Avatar
your o2 sensor is reading way to much exhaust flow due to the restriction of your catalytic converter being cut out the picture. search the how-to section for a spark plug non-fouler to plug your o2 sensor in. It works.
Old Mar 29, 2007 | 10:27 PM
TurboIX's Avatar
I have a highflow and my light is on...Should of just got Test pipe if the high flow was going to throw a cel...
