car stalling while driving
Old Apr 8, 2007 | 11:29 AM
19.5PSI's Avatar
any idea what would have caused this?
i'm driving doing about 80mph on the highway, slow down to about 50mph getting off and off ramp, down shift to 4th and the car dies. i didn't notice until the power steering went off.
i had a cone intake with a mail-in flash and recently just upgraded to an AEM intake and a tbe with a hi flow cat, MR bov but no reflash. any idea why?
now anytime i'm going about 40mph to a stop real quick, the rev drops and sometime it'll stall and sometimes it'll sputter but recover.
weird.
Old Apr 8, 2007 | 11:32 AM
Curt@MrLed's Avatar
Former Vendor
check you bov..
Old Apr 8, 2007 | 11:38 AM
Genesis8's Avatar
Originally Posted by dafarmer69
check you bov..
+1
Old Apr 8, 2007 | 11:41 AM
NocturnalEVO's Avatar
did u put ur mr bov to recirc back into the intake?
Just check ur bov first, make sure it recircs n all the hoses/clamps are tight.
Old Apr 8, 2007 | 11:53 AM
90GSX-03EVO's Avatar
Intake is probably messing up the metered air readings across the MAS. Diverter valve is probably also hurting you because some of your metered air is getting diverted toward the MAS instead of back toward the turbo inlet. I'd also guess that you have your diverter valve installed backwards.
Old Apr 8, 2007 | 12:26 PM
ninja808's Avatar
Mine did the same thing, and the cause was my bov that I had changed out. It would do it most if I was slowing down quickly at a light or stop sign. I ended up going aftermarket w/recirculation. Works fine now.
Old Apr 8, 2007 | 02:36 PM
bluebyu36's Avatar
bov or intake
Old Apr 8, 2007 | 03:05 PM
grillpt's Avatar
My car will stall if I am using a lot of throttle at low revs and I push in the clutch or do something that load is being pulled off the engine. It hiccup's real bad and will die. It's done it ever since I put an intake on, even with a flash. I'm just concious of it now so I automaticly blurp the gas so it doesn't die out.
Old Apr 8, 2007 | 03:57 PM
bluebyu36's Avatar
put the stock intake back on.
Old Apr 8, 2007 | 07:26 PM
Red05's Avatar
Originally Posted by bluebyu36
bov or intake
Had the same problem with my GSX when I slowed down was my BOV.
Old Apr 9, 2007 | 09:04 AM
19.5PSI's Avatar
i'm going to take a look at my Bov any chance i can get (it's been freezing outside). i originally thought that might have been the culprit but wasn't sure. i had the intake on before the Bov and it was fine so i don't think it's that.
thanks everyone.
Old Apr 9, 2007 | 09:08 AM
19.5PSI's Avatar
yeah i made sure of that when i originally installed it. the one thing that was bothering me was the fitting of one of the hose. i felt that it went on too easy and wasn't as snug as i would like for it to be. when it gets warmer i'm going to take everything apart and reinstall it.
Old Apr 9, 2007 | 09:43 AM
If the compressor bypass valve is installed correctly, then the only thing left is the intake itself. Your MAS readings are getting screwed up either by the filter making them turbulent or the hard pipe creating noise.
Aren't those AEM intakes known to cause problems like this?
Old Apr 10, 2007 | 05:51 PM
19psi's Avatar
did you check your battery?
You might wanna double check and make sure the connector is on there tight.
Old Apr 10, 2007 | 07:21 PM
mifesto's Avatar
that would be pretty hellish if u stalled during a turn and u didnt have enough time/strength to turn it back straight lol
